Some real life weathering pics of the Phantom..
I thought these may be of interest in showing the effects weather has on specific areas of the Phantom..
These are posted under "Fair Use" http://www.copyright.../fls/fl102.html for the purpose of illustrating the effect that weather, climate has on the air-frame.. Posted only for educational purposes.
View attachment 60123View attachment 60124View attachment 60125View attachment 60126
Danny
Interesting photos Danny.The one I intend doing has some weathering on it.So I'm going to have to have a go I suppose.I once tried the peeling paint effect on a Zero.I used masking fluid.It worked but didn't look realistic.I will have to try salt.Are you going to give it a go?.
Interesting photos.
A good way to get the worn off effect is..... to rub it off. Literally. Spray the top coat on and wipe it while its still wet. You can make a right pigs out of it, but it can also look rather good. The paint just needs to be WET and not half dried.
I have done it a few times on armour with good effect but never tried it on an aircraft...
Those are USAF F-4s and appear to be rather war weary. The US Navy ones I have studied appear to have been maintained to a much better standard. I suppose being at sea the paint has to be maintained and the aircraft washed regularly. The common weathering I have seen is a lot of soot and burnt metal around the tail area.
This is one problem I'm not ging to have............ :P
