I've decided to start a thread as I'm just starting to adjust and modify a few of the kit parts to make my intended subject.
My subject is an Eastleigh built Spitfire Mk Ia which first flew in January 1940 and was lost in March of the same year. It will be nice to do a pre-Battle of Britain aeroplane, with the somewhat less familiar markings it will carry.
To this end I have started the following:
1 Remodel bulges on cowling.
2 Remove strange lozenge shaped plates on top and bottom of wings and replace detail.
3 Remove crowbar from door.
4 Scratch build early circular shaped voltage regulator box to fit on back of frame behind pilot's head.
5 Reshape spinner and propeller blades or order replacements (haven't decided yet).
6 Order Barracuda set to replace kits metal covered ailerons with fabric covered ones and also oil cooler and radiator.
7 Make the proper style of seat cushion for the metal (not composite) seat fitted to early Spitfires.
I'm sure there are other things that some enthusiasts would change but I'm building an early Mk I from a Mk II kit and my alterations are to cope with that, not the fundamental shape of the kit about which I'm not concerned. There may be other things I need to do about which I am as yet unaware, we'll see.
More when I get back in a couple of weeks
