Where do you get that stuff from Laurie?\ said:Adrian try these. I rarely use Tamiya tape after finding these.
3M Fine Lining Tape Blue. Bit tougher and slightly better seal
Fine Spray Lining Tape. Very easy release and going around corners.
Both are available in a number widths. Also easy to slice a thin piece.
This first picture gives an idea of the crisp clean lines and also the versatility of these tapes.
Also use the green as it more flexible for canopies.
Both seal better than Tamiya. Both stretch View attachment 128001 View attachment 128002 View attachment 128003
Hi guys I thin all my tamiya paints with ipa it's cheaper than x20a and I can't tell the difference maybe it cures a but quicker all I would say is experiment on a scrap model just my thoughts\ said:The question regarding using water based thinners with Tamiya paints wasn't posed Laurie, if you read Adrians posts.
Whilst I'd never advise using Vallejo thinners with Tamiya paints, many people have thinned Tamiya with water & say it works ok( not something I'd do!)
If you have a local body shop supplier Rick they should have it. These are on Ebay. Tried Amazon but they have few contacts.\ said:Where do you get that stuff from Laurie?
Hi Colin\ said:What's the smallest width that the 3M tape comes in?
3mm is the smallest I can find, I guess your cutting it down by hand Laurie?
Is there any difference between the green and blue types?
