i got the `ole`bit and the `mon ami`as for the rest its all french to me.........
mobear
mobear
\ said:Fantastic Ron, the outcome really is amazing. When do i move in, can you pitch me a tent mate please lol.Seeing as how the place is named after you, you can kip where you like......Just think of the fun you could have with Happy Hunter charging around on the canal too!!
Nice one ole.....It means "Just a play on words, my friend."......or words to that effect!lol\ said:i got the `ole`bit and the `mon ami`as for the rest its all french to me.........mobear
Thanks John, I knew there was something missing......I found the missing bolt under the work bench and stuck it on with super glue. The PAK looks far better now.\ said:That PAK40 is very nice Ron, like you say "loads of detail". We're not rivet counters here and i'd be happy with that mate, by the way, there's a bolt missing:grinball1:Have fun, John
Now thats funny, i have tears rolling dawn my face. Thanks me old china.\ said:Thanks John, I knew there was something missing......I found the missing bolt under the work bench and stuck it on with super glue. The PAK looks far better now.Thanks again,
Ron
Cocktail stick point should be able to do it\ said:I'm going a bit silly and having a go at the pea pattern or similar for the crew smocks....I don't know why either. I can just about see the figures on the sprue!!
Is there another bolt knocking around mate, looks like you found the wrong one, that one looks like it has the wrong thread.\ said:I found the missing bolt under the work bench and stuck it on with super glue.
Hi Lindsey, I used ordinary Vallejo acrylics for this, but any matt paint will do.....Start with grey, let it dry. Then black, then brown/rust last. When dry, get a fine wire brush (not those you remove rust with!) and very gently run the brush down the 'tin sheet' Don't press down, the weight of the brush is sufficient. this should leave a hit and miss with the colours and leave a couple of shiney bits too.......\ said:hi there ron a question on the tin foil that u placed on some of the windows. to get the worn out metal look did u brush it with black "neo magic" (not sure what u call it over there). reason i ask is that i have tried something similar on my dio but it still looks quite shiny .... cheers lindsey
