Steven's 25cm German Heavy Mortar position 1/35 CMK
Terrific work on the sandbags Steven. Although all your time is being spent on the dio have you had a chance to start on the mortar yet??
Thanks Steve - no not yet but i have put it in in its basic components just to get at feel for the size and check everything
Have limited computer access at the moment so jumping at the opportunity to post some more updates
more sandbag with a box for storing grenades - will be well stocked at the finish
Armored loophole - have more sandbags now
The ironband and staples are going on - wip
Details we will be seeing very little of in the finished dio: Iron T- beams reinforcing the roof
For the roof I am working loosely from a schematic drawing of a mortar position in Dr. Stephen Bull's Trench
( No copyright Infringement intended picture is purely for illustration)
IRL at this late stage in the War the Roof would be a sandwich construction of earth, timber, gravel, concrete, and Iron Beams.
Only the parts of the timber and the iron beams will be shown.
Hi Steven Terrific work all round, the sandbags what are using to make the and how there brilliant :thumb2:
Pete.
Steven, have you got a contract with defra, and the ea they usually need sandbags now and again, … has anyone seen my miliput, it was here a minute ago.. Steven...
Great stuff and scratchery detailing buddy..
Thanks guys for the comments - they help keeping up my spirits while I am up against a merciless deadline if I want to enter this into Danish Open 2018 alongside the combi - shadowbox dio - the 16th of September.....:cold-sweat:
:smiling5:
staying with the sandbags - parados done, glued XPS to create terrain profile and to save material
here in various stages of painting (mix of panzer Aces light mud and Vallejo Iraqi sand) - a bit on the gray side, will be more yellow
The pit
I have painted the inside of the pit - try as I may, all the the methods for turning evergreen into "wood" I use always end up looking like the furniture of a 16th Cent. castle... ah well, not much of it will be seen and will be full of muddy footprints.
Steven .
Don't think this could be any better. That light is suberb , pity as you say its a bit cool in the output colour, but your idea should work to alter that .
That wood in the last photos is great, don't change it !
Hope you manage to finish in time and good luck .
John.
You've turned plastic into wood very successfully in my opinion. All looks great.
Gents, thanks for your comments finally found some time to post
Trench:
The sandbags have received a wash of raw umber
The pit: - With the star of the show - a Right dramaqueen - in place andnearly done
view of the pit with the principal accessories in place in various stages of completion
The Hun has nicked an old weathered table form somewhere - will be used for maps and there will be some aerial recon photos on the wall above
Table has been painted and chipped using chipping medium - and yes, the lantern is missing - more on that at a later stage....
(One of the wheels is still on the spure)
Shells - half and full load- two are still in their wicker transport baskets. Like everything else in the kit they are really nicely moulded. I tried to cast the shells to make more - I wanted to have some standing outside the entrance, but I
Completely budged it, so the ones included in the set will have to do
A close - up pf the beast - a pain to build but worth it....
Great , Steven it has every thing. Pity about the shells, but looking at the layout anymore may crowd it out. Waiting to see the beast painted!
What's with the light ?
One of my favourite builds on the go at the moment. I really do enjoy your updates. Keep up the great work
Thanks Gents - Glad to be able to share my toils and troubles with this build.
Speaking of troubles:
Lantern - troubles (*que dramatic intro*)
I was generally very pleased with the led diode from lights4models, only drawback form my perspective wiring it into a leg of a table was that the resistor was scolded pretty close to the base of the diode. as I had to cut the wires (resistor was too big to thread through the leg) I had to resolder them. Now, I am not the best of soldering - honestly I do not even qualify to be amongst the worse... My fiddling and many attempts at soldering the very thin wire I thought might have overheated the diode. I initially thought it was the resistor but it did not work with a new one either.
I had a spare from lights4models. I found that I could use it without cutting the wire, I tested it - it worked, then it explicitly stopped working and was adamant in remaining so...
Key take - away:
The very thin wiring is a hassle for an inexperienced solder - in the lights4odels ones the wiring is a solid metal rod rather than copper threads, meaning that it can be bend into - and will hold - any position but it is very prone to breakage - especially when the coating is removed
So, Nothing was fixed permanently, and I had some flickering led (3mm) from a danish company. I bought them after seeing a clip on facebook, I wired them up did the soldering and they worked the treat - only problem is the light colour. They were termed "orange" - the movie clip showed them to be a very yellow hue which is what I was after.
The light - even after I wrapped it in two layers of yellow filter is still very - orange - more akin to ambers in a bonfire than the flame of a candle
I tried to put filter film onthe glass of the lantern as well to no awail - still very orange.
See for yourselves:
I have ordered some new ones but they won't be here until between the 7th and 12th and bearing in mind that the deadline if I want to enter this into competition that bleeding lantern it is a spanner in the works.... but come hell or high water there will be a flickering light in my pit - dammit...
Steven.
Yes I can see your problem, just needs more yellow. Such a shame the first led failed.
Hope you get a replacement in time as that light was a real show stopper.
John.
