Hi folks,
For a group build in Facebook I started my first aircraft... I've been building only vehicles till now...
So here is the work in progress ;-)
Already weathered with washes...
For applying the decals I used the following method :
First a light coat of tamiya clear.
Second the decals applied with softener.
Then (before drying completely) another thin layer of tamiya clear.
After drying one day a thin coat of Vallejo Matt varnish.
That's it ;-)
The base should be an airfield...
So I played a bit around with plaster ;-)
After applying grass and dirt an oil it looks like this
And then I already coated the comrades with primer ;-)
So hope you like it ;-)
Cheers Benny
Gesendet von meinem GT-H9500 mit Tapatalk
That's it ;-)
Cheers Benny
