I have tried many types of superglue but it has never met expectation. All that pe needing to be glued onto the Avenger was a real problem, getting it into the exact place and then holding on keeping the piece in place while the glue takes hold. But, only too often the glue did not grip or at least not in the advertised time only too often falling right off again. I tried all different types of superglue, different viscocity, different makes etc etc and I have never been satisfied. I have tried putting less onto the part, more on the part etc etc. I also tried accellerator and that does not seem to work as advertised either....
Until last night.
I have some pe seatbelts to glue to the Spitfire seat and I tried the new superglue supplied by John, the Expo brand, two types in his shop (bought both), 1-3 second drying time is the one I used placing a small dap at the top of the shoulder belts and slowly offered it up to the back of the seat and, it gripped immediately and thankfully was in just the right place. I needed to get the belts to hang properly with another small dab lower down and again it gripped immediately. Same story for the lap belts.
I was amazed, it was so easy. Maybe with this ca glue that really is superglue, I might actual stop hating the use of pe...
I recommend it....
Until last night.
I recommend it....
