T 38 Amphibious Tank 1/35 scale by PARC models.
Then I looked, relief was transformed into horror. WERE the tracks were on the wrong way round, I must have mistaken the front for the rear. doesn't look right to me.
The real crew might have made the same mistake — there are plenty of photos of tanks with the tracks on wrong. Granted, only a small number of them would have had this, but it’s not unique to modellers.
They sit so low in the water that you only need a short length of upper track run on each side
No bogies required and the lower hull could be cut down to reduce height and therefore the amount of water needed......
Ah great idea, with those photos and suggestion I have a plan !
Bad luck, John - I have to admit that I have put the tracks on backwards, on several models - but done it on both sides, so at least it looked the same. Now I check, not only the instructions, but 'net pictures to make sure they're correct!
Thanks Dave, does make me feel better knowing I am not alone. I 'd looked at the picture on the box, several times, but it was showing very little track ends.
:nerd:
Thanks Jakko, kind of you to say, but I would never have lived it down :smiling::smiling: the Rabble would have had a friendly field day.
Thanks guys, ideas are " flooding " in.
Might get the Hobby Boss version as well .
John.
Just picked one up on Evil bay for £ 15.89 including postage, not bad , normal price is around £ 24.odd :smiling3::smiling3::smiling3:
John, lovely work, now whats this obsesion with rusky stuff lol
John, lovely work, now whats this obsession with rusky stuff lol
Bob. It was lovely until Trackgate ! now sitting in a box waiting to jump into the water.
Me obsessed Russian , what ever gave you that idea :smiling3:
Did I miss something :thinking: I’m sure something was getting built then I see it got unbuilt....and where’s the fire:tongue-out:?
I’ve been beaten by a cheap kit before so don’t feel too bad mate! Live and learn.
Hope the Hobbyboss version goes a bit easier!
Well John, we've all done it. Sorry this one didn't work out.
John,
the HobbyBoss Version? - WOW, that has individual track links - around 90 a side! - I have the HB T-37A Izhorsky version in the stash - I've looked at it a few times, but the links are a bit daunting!
Si it was over in a mear flash
So, buddy no wonder you missed it, it was all over in a link :smiling2: Nearly a fire but managed to control myself .Well the Hobby Boss should have instructions that may make sense!
Thanks Peter, just cross that after all the help I go and do that .
John,
Oh !
Not this is it .
Well if it is I shall damed well beat the crap out of those tracks, have jig, will glue :smiling2::smiling2::smiling2:
Says the man who's building an armoured car with - what was it - 138 links per side? :smiling::smiling:
Maybe Pete, but Dave has an advantage ----------------------- he knows what he's doing.
Thanks all .
Not much will be done this week as have been asked to do a small roof for a mate
Some nice 1/1 , ask me how I feel by Friday night !
John .
John,
as far as I can tell, the only difference between yours, and the Izhorsky version is the turret - the rest is the same I believeizhorsky.jpg
Come on in ,John, the water's lovely!
let's see that baby in the drink, it will be brilliant.
Or you could always try aeroplanes.........:upside:
oops!!
Not the best result I have seen. Looks like you have a great solution mate. Wonderful support from the guys. Look forward to seeing what comes out of the ashes.
Sorry, sorry I didn't mean to suggest you set fire to it. Oh :poop:
Nice John - should be a lot better to assemble. Hobbyboss stuff is quite good
John,
Simon and Dave thanks, looking forward to the new Hobbyboss arriving this week. Will be put to one side for a while.
A start has been made on the base Neil, sealants at the ready.
oops!!
:smiling3: Its ok Steve, no it wasn't any good, but it will be soon.
John.
-----------------------------------------------------------------------------------------------------------------------------------------------------Progress has been made, a section of pink foam was found in the heap of that will come in useful at some point. Sure we all have one.:smiling:
Adopting Simons idea of the T38 swimming I found a piece of suitably thick foam. Thick enough to allow me to sink the hull into a pre cut hole. I could have removed some of the hull by saw, but the amount that would be left to attach the front sprockets on would have been very little. With this in mind I did the deep hole as I had done with the Panzer.
First was the setting out.
Measures approx 185 mm x 170.
Above you can see my rough lines for cutting away the front foam.
Cutting through the foam to the line , as above.
Once the first cut had been done a curved line was cut into the foam from the top. Then more cutting into the line from the front edge. This will give you this, after a slight twisting of the saw and chisel to remove the curved section.
Once the bench top was clear of bit the model was placed in the middle and an outline drawn round, leaving enough room for the tracks and outer parts. Taking a Stanley knife and making lots of cuts in each direction allows the foam to be removed with ease, though cleaning has to be done to the base.
The tank is now placed into position for checking.
I then glued the foam to a section of 9 mm ply and placed some weights on the top.
To the sides ca be seen the edge section of 6 mm ply, I had a beautifully figured sheet in the work shop for years. It wasn't often a sheet would appear like this so had to be kept for special use !
Tomorrow I hope to get the sides on, i've allowed about 6mm all round to allow for plaster for the bank and top and for the " water "
Thanks for looking in.
John .
Suppose this should be in the Diorama section , sorry.
Evening Mr R,
Top stuff doing a submerged tank....I very much like where this is going :nerd::thumb2:
HI John sorry to hear about the tracks bein back to front but i'll say this I looked ok to me I would never have noticed
chris
