I read somewhere (in connection with using Eduard canopy masks — it might have been the seller of Eduard masks) that it is a good idea to use T-cut on the masked surfaces to make sure that they are clean and so make it easy for the masks to stick (which is obviously necessary, especially around the edges).
T-cut is a mild abrasive (although shines cars OK) and contains ">= 50 % Aliphatic hydrocarbons and up to 15% Anionic surfactants".
I rang the manufacturer and they advised against (not surprisingly), saying that it might turn the polstyrene milky.
I have just done a test and after polishing it off there no sign of milkyness yet
Is T-cut necessary? Would soap and water be sufficient to get good adhesion?
Thanks.
Thanks.
