I forgot to ask. How do you apply your grime ? I tried brushing it carefully in vertical lines, let it dry a bit, then I'm stuck. What do you use to blend it in ? Is it water based or not ? I can't work it out.Vallejo Streaking Grime
I do a section at the time but I just brush on a little odorless thinner with a wide brush, just to make it a bit damp and then add the first grime colour and blend it vertically with another smaller brush. Let it dry for a bit and then on it again with the same grime until happy and then move on to a different tone. In all I used three different "grimes" on this model if I can remember it correctly?I forgot to ask. How do you apply your grime ? I tried brushing it carefully in vertical lines, let it dry a bit, then I'm stuck. What do you use to blend it in ? Is it water based or not ? I can't work it out.
I'm sorry I didn't see this comment earlier, but a huge thank you for those kind words!That tank is absolutely flippin' marvellous.
Meh, it's looking "alright".
Trying is an art in itself I guess.
10 points to Slytherin.
