Tamiya 1/32 F-51d
beautiful work and detailing, you are building one of my all time favourite aircraft.
scott
Very nice. I've never tried salt chipping but it seems quite useful in larger scale.
Very nice work on the wheel wells Theuns. It's coming along a treat.
the ammo bays look extremely good. Just don't forget every tenth round was a tracer and was painted yellow
All looking very nice. I might have to try 'Big' scale again soon.
Here is the undercart strut. I painted the slider part of the oleo Alclad and the rest is humbrol steel.Starting to look like a mustprang now...Now I just need to figure out if the pannel marked with red arrow was removable for maintenance. It would be a pitty to hide the nice PE filter under it.Theuns
So, as painting time comes colser I have had to experiment with the meatls I will put on.The mustprangs in Korea seem to have been very dull and weathered.I painted a plastic spoon to see what works the bestLeft side is my usual airframe alluminium over alclad grey on the bottom corner and alclad black on the top corner.The right side top is duraluminium over alclad black and the bottom dura over alclad grey.All has been sealed with alclad semi matt clarcoat.To my eye the airframe alluminium over black can work for the darker areas like exhaust pannels, gun bays ect but airframe allu over grey is to grainy and looks to "silver"The varition in the duraluminium looks closer to the pix I have seen.I have also heared that some guys wil (after all different pannels are painted) shoot a coat of say alluminium over the wholw thing to blend it all together.Any ideas on this??Theuns
It's difficult to say looking at a computer screen, but it seems like the grey primers give the best effect.
The grey primer makes it allot lighter with the same amount of metal ...
It is a pitty I dont have a better camera to sow how good this engineering on the undercart is.
The oleo was wrapped in tin foil to look like chrome
Theuns
Here are two extra tail sections they give in the kit.
I experimented with spraying alclad grey primer , masking off some pannels and then spraying alclad black base. Over all of this went 2-3 coats of duraalluminium.
I am rather pleased with the tone difference I get with one "colour" of alclad.
As for the rest of the model, it hs been primed with alclad primer and just a few areas need a little attention, then a final sanding and "metal" can go on.
Theuns
