I’ve found loctite gel CA more reliable, but it can leave residue that needs clean up. On larger PE parts, like schurtzen, I use epoxy as the main adhesive, but hold the part in place while the glue dries using CA. Give blue tack a go Bob, it’s easier to use than tape, and is infinitely flexible.Hi Tim, one to think of?
I use thin CA, should I use thicker CA?
Ideally I should use masking tape to hold in place then a looper to fix. I have a clamp normally used for wooden ships so that might be handy to hold bigger stuff while I try to fix pe.
Will get out the scrap plastic first
