Tamiya 1 / 35th Scale British Universal Carrier MK 11
toto
Tom
Edinburgh
Another victim for my " Pushing Back " WW2 diorama build ....
looks relatively straight forward ..... the intension being to build into sub-assemblies prior to painting, final build then weathering etc ..... we see how it goes ...
The usual destructions .....
rubber tracks ....
sheet of decals .....
and the first of the sprues .....
and more including the bottom of the hull etc ....
Body sides, wheels and stuff .....
and a couple of figures ..... not a huge counts part by any means ...... even I could maybe manage this .....
cheers
toto
Did this one recently myself, its a nice kit, enjoy it buddy.... will follow along.... always good to see how others tackle the same kits... 8-)
Well, the dust has been blown off the box .... 😂
I'm back up in Dounreay and can't access my Pushing Back diorama or my priming paints etc ( don't want to use paints in my accomodation ..... just asking for trouble ).
So decided to crack open this kit for something to do. I intend to attack thisthe same way as my Pak 40 and my Simca 5 ..... and my Kublewagon. Buildinto subsections and prime /paint in sections prior to final assembly.
I will probably have 4 or 5 kits to prime at once so itsworth the setting up and cleaning and putting away operation with the air brush and painting booth.
I need to remove my diorama into my kitchen ( on top of the dogs cage ) in order to clear sufficient space to set up for either painting or plaster casting.
Thereare certain spaces in the mancave that I just wont use for wet rasks like next to my PC set up or editing / photography equipment. I will have dedicated space for this once my RC planes are either sold or rehomed.
Anyway .... more on that later.
I will take a few photos along the way as usual and post up. I only have my works laptop with me this week so it could be Friday before I post up this weeks progress.
Cheers for now
Toto
If its the same kit I had, and you want the driver in position, you have to get him in position before attaching the main front bulkhead, otherwise you can't get him in afterwards, just something to think about....(y);)
Thanks for that kind Sir,
I have only done the first couple of steps so far. Its a pita to have to have the driver built and painted so early on though. Same with the wheels and track ..... if you are priming and final coating the bottom half ..... how do you do that unless the wheels are done seperately ? You wouldn't be able to get a decent finish behind the wheels and suspension.
Maybe I am looking too much into it.
Toto
I try to go through the instructions and work out what sequence I want to do things, not necessarily the same sequence as in the instructions. As you say, sometimes you may need to paint/weather behind another part, eg: tracks, so you may do the chassis first, including priming, painting, maybe even weathering, and do the wheels/tracks separately, including priming, and then join them at a later part in the sequence. Theres no right or wrong way, just do whatever works for you... I do tend to prime and paint things whilst they are still on the sprue, especially small fiddly parts, and/or split the build into sub assemblies, but other people may not, they may assemble everything and then prime/paint.
Planes is a prime example where most peeps will paint and weather the cockpit interior early on, as obviously once you've joined the two halves of the fuselage its then almost impossible to paint the cockpit interior afterwards.
Made a bit of a start but nothing to shout about
and .....
and .....
Nothing exactly hard so far so I will continue and get some of the other sub-assemblies done now ....... amongst other things.
cheers
toto
