This is my build log for what will probably be my only modern jet build, not a big fan of modern vehicles, military or civilian but this aircraft is just awesome, designed and built around the massive GAU-8 Avenger rotary cannon, enough waffling, a couple of pictures of the start...
The usual shot of the box
The main components being assembled, the fuselage halves had put up a little bit of a fight but once i get the filler and sandpaper on it
I'm going to show it on a hard standing without the pilot so i thought i might have a go at scratching the TF-34-100A High Bypass Engine with the covers off, this is as far as i've got, lots and lots more pipework and wiring to go.
Any comments good or bad welcome as usual
Cheers for looking
Cheers for looking
