Tamiya 1/48 P-38 Lightning
I've been itching to get started on this since Santa dropped it down the chimney. Thankfully it survived the fall and with the Beaufighter done as a warm up I cracked the box open today.
By all accounts it's a very well engineered kit so providing I don't do anything particularly ham-fisted it should go together well. I doubt I'll have it finished by the end of Ian's Group Build though, hence me posting it separately.
Firstly the box.
As usual I doubt I'll be totally historically correct, but I'm aiming to build the F version in a similar colour scheme.
Following the instructions I started at the cockpit. So far the parts have fitted together perfectly, although I left some apart for ease of painting, and assembled them after. Sides were left on the sprue for now so they are easier to handle.
Decals seem to be settling down nicely, annoying mould line visible at high magnification!
And made a start on some of the detail painting. New glasses are helping tremendously.
I've got a busy day tomorrow but hoping to get a bit of dry-brushing done to pop the details out a bit and maybe add a little wear & tear.
Thanks Ian.
The fit seems very good indeed. Last night I dry fitted the cockpit sides just to see how it looked and had a devil of a job removing them, everything locks into place so tightly.
Hi Andy
Front and centre for me. Being Tamiya the fit should be good as you seem to be finding. Really neat work on the cockpit. New specs certainly have enabled very fine detail painting. Love that instrument panel.
If it goes as well as the Beaufighter you'll have a cracking model.
Thanks Jim. I'm certainly finding things easier now I can see what I'm doing! They don't help much with the wobbly hands though lol
Not much progress as I'm a bit under the weather. A few guys at work have been off due to flu like symptoms and I think they've passed it on to me! :rolling:
Cockpit now fitted though, after a bit of light chipping, dry brushing and dirtying up with washes. Seat strangely comes at a later stage.
Off to bed now to try and sleep this off :sleeping:
The office looks good Andy :thumb2:
Have they recently come back from a trip to China? :)
Looking good, and it’s a nice big cockpit opening so you’ll probably even be able to see a decent amount of this effort when the model is done :)
Thanks everyone, trying hard to do justice to a great kit.
I hope not Jakko, that doesn't look good!
Feeling a bit better after a nap I decided to jump 40 sections ahead in the instructions and fit the radio gear. I've no idea why they leave it until almost the end as there's no reason I can see for not doing it now (famous last words...)
I could have brush painted this but after cutting some strips of 1mm & 2mm masking tape I think it came out better sprayed.
I didn't fancy masking all of the individual radio parts though so they were sprayed in black and the silver bits picked out by brush. Some of them need another coat.
The armour plate behind the pilot is probably the wrong colour but I followed the instructions for a blue/green mix. Seat is loosely fitted as I want to chip & weather it a bit, and may attempt some belts rather than using the kit decal.
Looking to be an excellent representation of this early mark. PaulE
Excellent work Andy. It's a pity Tamiya chose to represent the two throttles with one that's double the size!
Thanks everyone, I really appreciate the kind words.
Pete, I know aftermarket PE addresses that issue but I didn't want to over complicate things.
Hi Andy bit late sorry, cracking job on cockpit area very neat and tidy:thumb2:.
Thanks Pete, I'm trying my best.
Cheers Ian. I don't suppose you have any reference shots of the cockpit / radio area do you? I've seen a few, including yourself, add wiring to that area and it seems a nice touch since it'll be quite visible. Could do with something to work off though and all the pictures I have are from ground level.
