Looking great mate, they set it off really nicely, this will look amazing on display on a shelf
Cheers for that Dougie, I shall keep your advice close to hand.\ said:Is not easy. You need to get a really even coat of paint all over without going too thick.
Next you use finer micromesh than you want to... If you go too course you have deeper scratches to remove from the paint but you have already removed a lot of the overall thickness by then. You just want to remove the orange peel to a desirable level with the finest grit you can get away with and then use compound for the shine.
Stay away from edges and corners where possible as they get rubbed down more and the paint tends to be thinner.
Mark has done an exceptional job on this, his patience and pace seem to be spot on.
Thanks Mark, fantastic advice and eloquently written. I'm just preparing the body for my next build (59 Chevy Impala) I need this to be exceptional as it's such an eye catching car!\ said:Thanks guys for your kind words. Dave your question about rub through, well thats just it your rubbing it and thats where your going wrong.
I prefer to think like im 'cutting' it. When you wet shave do you apply pressure like your rubbing? Of course not you go lightly and let the razor cut.
Its the same with micromesh, you need just enough pressure to hold it against the surface (this means no pressure really, like your holding a butterfly wing). Dont rub it back and forth like your sanding something, go in light straight cuts from left to right and count them. I did 40 cuts before moving up to the next grade ( this varies from one person to the other), as you go up to the next grade it will take less off. Also listen to the cut, if its scraping like your sanding something your going too hard. You want to listen for a high pitch squeeky sort of rizzle sound (is the best i can describe it ) and make sure you do it wet to keep friction heat down. Use lots of water, too little and the paper will 'grab' the paint and graze it ( especially on freshly dried paint ) and take your time dont rush it.
I did one panel at a time divding up the sections. This ensured i didnt go uneaven on one place.
Don't know if that helps or not
