The only Morgan I have ever driven was a 4/4, in bright red, so this model will be done in Ford Radiant red, with a light tan interior, the kit I'm using was bought off ebay, but was missing the clear parts when it came, but I kept the kit and managed to get another built up one to use as a donar car, but that one the front screen was a mess, but I did get the top up option which was as new, so this model will be built with the roof in the up position.
I built up the parts on the bodyshell that needed to be painted body colour, (Front Grill surround and rear lamp pods), as I am building this kit out of an incomplete kit, I am grabing some parts from the built up model I stripped down for parts, in the kit the front grill surround was broken, I used the one off the donor car, I had to clean off the glue residue, but it turned out o.k, for most of my builds I use good old Cellulose paints, but for this build I decided I would give automotive Acrylics a go, coverage was good and the shine right out of the airbrush was very good.
The seats are molded in two parts, the seat bucket and the back panel, although the back of the seat won't really been seen once the model is built, I still went to the trouble of making the join as good as I could, and has now had a small coat of Squadron white putty, I will leave this to dry out overnight before sanding smooth
Today (October 7th) I managed to get into the model room, it's the first chance I have had since coming back from Dublin, the body polished out very nice, and I didn't even need to break out the Minicraft drill and polishing mop, I used meguires NXT tech wax polish on a microfibre cloth, and after letting the filler dry on the seats, I have sanded them flat as well, and they have now had a coat of Tamiya XF-59 Desert yellow to match the interior.
