In the Bold Division T1E1 mine roller conversion set, the hubs aren’t correct. What you get is seven hubs per set of six discs: one for each disc, plus one to go on the outside. On the real thing, though, there are two hubs per disc, one on each side. This is clearly visible because the hub consists of spokes against the disc and a ring on the outside of the spokes — but with the Bold Division parts, you will only get spokes on one side of each disc, except the one at the end that will have spokes on both sides.
I first looked at modifying the
resin parts, but that’s a no-go for several reasons. One is that it would be very hard to thin down the hub parts to make room for spokes on the other side. The second is that the hole in the centre is too small, so they would also need to be drilled out. Last, the shapes and dimensions of the spokes are off a little. I know all this because over on Missing-Lynx, someone gave me this scan from the technical manual for the T1E1 mine roller:
Since the diameter of the disc is known (122 cm), I could work out the dimensions of the rest easily enough by doing some measuring in Photoshop. I first intended to scratchbuild the hubs, but couldn’t find a way to make the rings except by laboriously cutting them from plastic card with compass cutters — no, thanks, for 36 rings = 72 circular cuts … I can’t even make one that isn’t a spiral, never mind that many. At least. So, I turned to computer-aided design:
After a request on another forum, someone kindly printed up this for me from that drawing:
I need 36 hubs, so he printed 45 of them (minus one that didn’t come out right) in case I break some
Here is a comparison between the Bold Division hub on the left and the one I designed on the right:
That just left one more problem to solve: the hole in the centre of the disc is 5 mm on the kit parts, but needs to be 9 mm to match the real thing. The reason for that is because the real vehicle had an oversize hole for the axle — as you can see in the TM illustration above. Once you know that, on level ground, the axle lies at the bottom of the hole though the discs, you spot it immediately, asi n this photo I posted earlier:
If you look closely at the roller on the left of the vehicle, you can see the axle hub is clearly below the centre of the rollers. Even more tellingly, one of the outer discs of the front roller is further forward than the other five, which can only happen if the hole through it is bigger than the axle (and the crane is actually lifting the arm up a little).
All this, by the way, is so that the discs would conform to uneven ground and not hover over mines laid in hollows in the ground.
Enlarging the holes proved easy enough using the table drill in my father’s shed:
The stepped drill is 4 mm, 6 mm and then 9 mm (plus bigger above that) so it had the size I needed, but centering it proved slightly tricky because the hole in the plastic discs was 5 mm, so I had to centre it by eye and press the disc firmly down onto the wood with my index and middle fingers while trying not to hit them with the bigger parts of the drill
But look at the improvement you get for that work:
Another small thing wrong with the conversion kit is that the big bar that goes across the front of the tank, was bent:
This, I solved by heating it with a hair dryer, rotating it a few millimetres in front of it so it would heat up on all sides, and doing that long enough so the insides would get hot as well. Once I thought I had achieved that, I pressed it down flat onto a stone kitchen countertop and held it there until it cooled. That seems to have worked well enough
