Tamiya RCV211V 2003
simontie
but not being a Max Biaggi fan i have decided to use the bike for a Repsol Honda and decal it for the late great Nicky Hayden,
i have a set of decals and the zero paints for this bike. it was a second hand kit that came with some parts painted yellow image.jpg
so I stripped them back as you can see still some staining but it will cover I hope !!!, the rest of the kit was intact.
Also came with camel decal set but ill use them elsewhere unless any one wants a set?
i already have a camel in the cabinet,
But first i need to tidy up the bench after my mandalorian build and then ill get on to it, posts as and when i can
simon
I'll be watching along with this one Simon.
Nick
Ok got a few bits done on this but a long way to go
wheels a nice fluorescent orange
engine all but complete
frame and body work, sorted but yet to be painted the body work was the biggest parts that required stripping some small bits of residue but happy i can cover or remove before repainting
Simon
I'm in ! - Such a sad way to end his life - 6 years ago this month :( This will be a nice tribute .........
I'm in ! - Such a sad way to end his life - 6 years ago this month :sad: This will be a nice tribute .........
Yes ironic really spend a life time riding on edge and getting killed in a cycling accident much missed in the paddock as well RIP.
Well not much progress due to other commitments but the weather is so great just now seems a waste to be in side!
ok parts ready for assembly forks rear damper frame swinging arm
parts for priming currently drying on the window sill after degreasing them
Still a bit of the camel yellow but confident it will disappear under the gray primer
more when i can
simon
Evening all, well small progress frame is built and engine is fitted along with swinging arm, forks exhaust all the other bits,IMG_2892.jpegIMG_2893.jpeg
body work has been primed ang hopefully i will get the several other coats on it over the next day or 4
simon
Just the decals to do … soon i hope
thezero paint has worked really well great colours just poor pictures
simon
Paintwork looks fantastic Simon. Hope the decals go on ok....
Nick
Ok well decals are on no really big dramas couple of small issues but im really please with them still drying off final pictures later once i complete the build and give it a wax
simon
Should say the heat gun i bought thanks to Mr Bowcat worked a treat thank you
simon
