Hi,
From here onwards is what you'll be liking Peter...figures. I lost the whole section on constructing the Dragon Tarawa Gen 2 figures but I saved the part where I painted the heads of two of them.
At the beginning I started out with four figures but now have ended up with nine. I have a mixture of Tarawa and Okinawan WindTalker figures...their weapons may be the same but there was subtle difference in uniform and webbing equipment. In tarawa the 2nd Marine Division war camoflaged blouses and pants. By Okinawa the 1st, 2nd and 6th Marine Divisions all wore jungle green or drab. Can anyone confirm if the 1st Marine Division in Peleliu were issued with the camo fatigues or just plain green/drab?
I would normally prime my figures before painting but I went ahead with the faces by first applying a base coat of flesh. It's a bit on the dark side and will need lightening...I over sun burnt them.:tears-of-joy:
View attachment 301979View attachment 301980
I have used all four figures from the Tarawa set including the lying prone and flame thrower figures with very little tweaks and grinding of the helmets so they sit more snugly.
I have also used four figures from the Windtalker set. They're not as detailed as the Tarawa Gen2 figs and were modified extensively. The 9th figure below is a little out of the ordinary coming from Tamiya's old Wehrmacht jumping from the Hanomag figure. This one needed major surgery.
View attachment 301982View attachment 301983
I slowly carved the leggings from the boot and built up the arms...
...adding putty bit by bit to beef up the arms.
Changed the head to a more agressive looking Hornet head added the back pack...
Found two actual Marines style shovel
A layer of nato black primer and a misting of white from above to help when painting highlights. I've still not decided to give him a bayoneted rifle or not hence the blu tac. Just noticed i haven't added the straps for the back pack and the bayonet scabbard which is basically attached to the side of the back pack.
More later on the other figure modifications.
