Trumpeter 1/32 SU-25 A Frogfoot
I have finished the ordnance. After a varnish coat, pin wash and some dry brushing with metal powders it now looks like this.
Overall I am pleased with how it has turned out. This lot can be put to one side ready for final fittings.
Now if the Quinta Studios detailing set does not arrive in tomorrow’s post I will start working on the engines.
Still waiting for the detailing set from Russia.
In the meantime I have been pulling together the engines. None of this will be seen so all I will do is throw some black primer into those places the sun does not shine followed with some dry brushing with metal powder using a cotton bud. That will be enough to bring out detail sufficiently to be glimpsed when peeking into the tail or intakes.
The engines
They went together really well.
In have also started work on the wings. These also are going together well.
Nice start.
I ordered some masks from Poland for an upcoming project. I received an 'order despatched' email the next day from the vendor, followed by an email from the Polish Post Office telling me...errrrr...something, presumably that they had the package.
The masks turned up after almost three weeks!
I doubt that a package from Russia will be any faster :)
Ordinance looks really good Barry, totally believable. Third set down resembles a couple of pin chucks :thumb2:
Hope the package turns up soon....
Nice start.
I doubt that a package from Russia will be any faster :smiling3:
I got my MRP order from Slovakia a week after it was ordered. Russia though is, as you said, another matter! It was nearly a week before they emailed t say it was posted and that was a couple of weeks ago....
Working on the wings there are some very vulnerable parts to deal with. I don’t want to leave these parts off until after the painting is done. So...
the answer is to cut them off and replace them with brass rod.
and here is the wing....
I did have a problem - see the transparency by the fin at the end of the wing. I tried test fitting it and I could not get it out whatever I tried. I should have painted the plastic underneath chrome before test fitting. I have decided to mask it and decide what to do with it after painting. I will see how it looks before deciding. I cemented it into place with a small drop of extra thin and did the same on the other wing.
By the way, you might notice an improvement in my photos. I now have the iPhone 12 Pro Max and I can get focus much closer in with just a touch on the screen...
Barry, I don't know whether this would be any help but issue 68 of Model Airplane International magazine has a comprehensive article on the Frogfoot and 1/32 Trumpeter kit build. Has several colour schemas. If you want a copy but can't locate that issue, I'd be happy to photocopy and send you the article if you send me an email address via PM.
Regards,
Murfie
Nice progress Barry, love the ordnance! :thumb2:
Steven
The engine nacelles are a poor fit and I have been struggling to get them in place, that done, I have a lot of filling and sanding to do. Pictures to follow.
There is a bit of an issue that is more usually found on Kitty Hawk kits not Trumpy.
Note part NN3 and compare the instruction illustration with the plastic and alternative metal NN3.
The next illustration is consistent with the former but not the parts.
However the parts are at least consistent with each other. You can see from the locations where they go. No real problem as such as it happens.
The Quinta Studios detailing set has arrived and I am very impressed. It looks much better than etch.
Instructions are good and I am looking forward to giving it a go and see how it goes together.
I will finish off the work on the engine nacelles and the undercarriage first though.
Regards,
Murfie
Thanks Murfie.
can you please send me a photocopy. I will pm.
Time to show some pics of the challenge I am facing with the engine nacelles. They just do not accurately align.
Above you can see where I used a sliver of white plastic to sort a mismatch at the exhaust end. It still needs a little sanding. The surface detail is also mismatched but I expect that to be pretty well sanded away anyway. I will scribe back some of this.
it was even worse further forward where I had to do a lot of cutting and sanding to make a space to fit the panel. I am not sure how I would have sorted that if I wanted the panel open as it would have looked obviously wrong. I am left with this below, lots of filling and sanding to do.
Further forward is the wheel well and that is not so bad, fortunately. It is very slightly out but not enough to notice, provided you are not zoomed in on it that is!!!
The intakes pretty much match up.
below are some of the cockpit components. I now need to sand away detail from many areas to be replaced by the detailing set.
The weapon pylons. I had to match the up to the stores to make sure there was a match. Some needed sway braces, some not, where I needed them I had to make sure the were positioned correctly for the specific store the pylon will carry. The instructions say nothing about doing this. The top two are aftermarket resin pylons as these are not provided by the kit.
a few more subs below.
in spite of the engine nacelle fit this is going together rather well. This is a very good kit.
Great looking work Barry. Well thought through on the intakes and stores as well.
I have removed the detail by scraping and sanding on the parts below ready to apply the Quantas Studios detailing set.
I am very impressed with this set which has some very good detailed instructions. I will be painting the above though before Quantas application. First though I want to finish off the sanding/fitting of the nacelles and then do a thorough clean up of all the dust........
I have been getting on with painting. The nature of the detailing set means I need to paint and weather first before application.
I have not used so many shades of grey and green before on a single kit.
I will post more before Christmas
Here is a quick look around the workbench to see where I am at. I won’t get much more done for a few days, if anything, as my Missus would kill me if I disappeared to the bench over Christmas. I won’t even get a few hours of peace Boxing Day as there are no sales for her to disappear off to this year!!!
Some parts in the box lid awaiting their turn including the ordnance which is complete awaiting installation in final fittings. The wings etc are just primed to awaiting to be fitted/painted.
here are the pylons and gear doors. These just need final matt coats which I will do when I get to this stage with the airframe.
Below the wheel wells, pin washes and dry brushing done, likewise the parts in the two pictures below that.
I have just applied a water based gloss varnish to the seat padding and control column bottom. I will be doing a wash once the varnish has dried. These parts also have some of the 3D decals for detailing to apply.
Here are the remaining cockpit parts all finished with varnishes, washes and metal powders waiting for me to apply the detailing set also pictured. I will do a detailed explanation of how this new type of detailing works out. These look far superior to etch and I can see this type grow in popularity provided it is ‘usable’. We shall see...
I probably won’t get a chance to do more before Christmas so have a great one....
I spent an hour with the Quintas detailing set....
These are described as 3D decals and are an alternative to etch detailing sets.
Well I have used etch sets several times and I have a love/hate relationship with them while my relationship with decals is pure hatred, so how do these match up....
just feel the love people.......
Materials used:
cocktail sticks
white glue
thick c.a.
warm water
fine pointed tweezers
cotton buds
Forget conventional decals, these are vinyl so they have strength and do not splinter and there is no carrier film. The printing and detail are superior to etch and, of course, they have 3d detailing and are not just flat.
Starting with the main i.p. I applied a layer of white glue over the plastic panel then remove the detailing part from the backing paper in the usual way.
I blotted excess water from the ‘decal’.
then positioned it on the panel, a perfect fit.
There are a couple of other small items to add, then...
the panel is pictured next to a couple of levers that need adding. I will use thick c.a. for these, they have more ‘substance’ than the awful etch equivalent so I am optimistic that this will work. I will wait though a few hours to make sure the main panel is fully dry before I attach these.
some small details to various parts, all dead easy.
A side panel, next to a lever to add, again I will do it after the main panel is dry.
Now, some parts need ‘building out’ and to be given more depth. You can see below a small part to be layered onto the larger side panel.
Easy peasy.....
but there is more to be layered on top of that... a lever needs making up from three pieces...
I used a small drop of thick c.a.
that’s the two halves together just the end to go as shown clearly in the instructions.
All done...
Below a side consol fitted but with a number of levers etc needing to be added later with c.a.
below are parts for the seat.
when I get back to the bench I will finish the seat and i will see how well various levers attach....
so far, very good indeed and very easy...
