Here are some (poor) photos of the skatebord, all painted and the tape removed and looking less like a skatebord and more like a U-boat!
painted with Vallejo model color paints weather and rust done with Oils.
I know that there are a lot of drain ports that are not blacked out, I did start to drill them out, but was soon loosing the will to live. IF I ever do another U-boat I will do them all, from the inside befor gluing the hull together....Which would involve a Dremel and some bur grinders, and most likely a vacuum cleaner!
Hope you like it.
It was a very easy build and the painting was a blast. So I guess now the cave is run in again!
Hope you like it.
