Afternoon Rocketeers from a hot and sticky Bamberg,
No damn end in sight and rain is not in our future any time soon. Over 30° C every day, but the show must go on. So...
Paul - Thank you my friend. I do hope your weather has cooled off a bit too. It's murder here in the Fatherland! Vette running yet???
Rick - Thanks too Sir!!! I didn't mind getting wet and it was worth it. It only lasted one day though and the temps shot right back up. The Steyr is getting crowded too!!! See below.
Richard - No worries my friend, as I do the same thing. I enjoy looking at a project and forget to comment too. I chalk it up to old age. I do appreciate you checking in and I want to finish the Steyr before I move on to the LOX trailer now that I have a complete kit.
Stevie - Hey my man, I'm having the same prob here with my Faller expert glue. It's so hot, it almost dries as soon as it comes out of the needle end. Makes rivet gluing a real PITA!!! BTW where is Juno or do you mean Juneau in Alaska. It's probably over 30° C there too though. I turn on the fan to hurricane setting and an go for it. I only hope it doesn't blow the tiny parts away. No more C word either!!!..….
So over the past few days, with the fan at max, I drove on with some more of the
crap equipment in the interior. I sliced and diced some tubing, strips of plastic, odd bits and parts lying around to build the regulator for constant voltage thingy. I also made the cable tunnel and added the angle iron feet for the reel rack...
Next up was the start of detailing the battery cabinet. I did the rivet thing and modified 3 hatch hinges from a Panther to make the bottom latches of it. I glued the loose pieces onto the regulator parts including the lifting eye that came from a tow shackle. One still has to be glued on the other part of the regulator thingy too. The two grey tiny bits are the mounts for the first part next to it. This assembly was all mounted on a plate behind the passenger seat and had some cables running here and there as shown in the ref pics...
Now was the time to see if it all fit in the Steyr...
Well kiss my grits!!! It appears that it will all come together in the long run. Had to race to the fridge for a cold one as a reward!!! Another view...
And another!!!...
And how it's supposed to look like...
Ok, and one more for the cheap seats in the back!!!...
I'm kind of happy that it turned out as well as it did. Nothing is glued so adjustments can be made. The bad news is there is still a lot to do to finish it off. I guess I just have to drive on with a hard…..You know the rest folks!!! 16 latches for the battery cabinet, regulator base mount and generator exhaust system are just a few of the details to come.
Thanks for looking in and I wish you all a cool week as it ain't gonna happen here!!!
Allen
