Here are the preliminary results of the poll. So far the suggestions that got less than 10 have been cut. Those with 10 or more are up for the final grind.
So with out further a do, the winners are......
Under a tenner. Any kit purchased for under £10 (or equivalent there of!) 19
The Desert. Any desert, any war. 18
Post war wrecked armour or aircraft. Found rotting in a field… 14
4 engine bombers. Nuff said? 14
Brail scale armour 1/72 Scale ? Can you see it? 13
from a photo. Post a photo reproduce it as accurately as possible. colour or mono 13
The devil is in the detail. Put as much extra detail on a basic kit as you can. However you can. 12
lands on an aircraft carrier 12
A figure build As in the singular A figure. 12
The battle for Berlin 11
Soviet Aircraft. Any type and era. Political hot pot that one
11
Anything with snow. 11
Locomotive If it is on rails its fine but lets try to avoid the obvious German railguns.. 11
Prototypes that didn't quite make it. Mass produced need not apply. 10
A classic from the seventies. Time to dig those cupboard queens up and build them! 10
Artillery, with or with out tow. 10
Sorry about the iffy formatting, but the info is sound.
The big question.Do you want to vote it out as to what is a GB and TB and SIG If so I will set up a new poll, or shall I just go for it and get the calender sorted.
If that is the case, if you have any preference to a subject being a 6 month or three month build please say so here.
Dont forget that the 1/24 scale or larger Aircraft SIG IS already on the calender.
