Weltkrieg 11 deutsche Werkstatt
Over the last day or two I have started making the tiles for he roof but found the molds I was using were not enabling me to get a fast enough turnover. So I set about creating a master for a mold that would give a higher yeald. That done I now have a mold that gives out around 90 tiles per casting with a section for half tiles. I got the grey colour by adding pigment to the resin.
As there is a small room with a roof on the side of he barn I had a go at tiling it this evening as can be seen below. All comments and suggestions are welcome as always.
The tiles are brilliant. Until I read your comment, I actually thought you had been chopping up bits of slate.
Don't tempt me Colin. In all honesty I don't think the barn would stand the weight if I used the real thing.
I have finally decided what vehicle I am going to have in the barn being worked on. Ian M inadvertently gave me the idea in his famo build post and I hope he doesn't mind me nicking it. I am going to have another Famo being given an over haul. As I have an engine block in bits and a few other things I can use I think it will add to the workshop nicely.
I have also decided not to put any more armour on the board instead going off piste a bit and having a comms truck being unloaded (something a bit different).
What a great work are you doing there Terry....magnificent ;)
Looks amazing Terry well worth the time it took to get a result like that
Great job
Thanks Gents much appreciated that's another big hurdle over come on this build.
I know the roof was a lot of work, but the finished result does speak for itself. It came out great.
That is one realistic roof. Unbelievable dedication here Terry mate.
Thank you both for your kind words and sorry for the delay in responding. I have got to say I am really happy with the way it turned out all that is left to do with it is some weathering.
Just a quick update to be going on with. The second Famo is coming along slowly very slowly infact. Of late time just seems to disappear so fast.
I have gone about building this one differently to the last adding PE parts before fixing the plastic parts in place (something I had not done on the first). I am not going to use all the PE as a lot of it wont be seen once the Famo is in the barn. I have the cab tilt to add but it is going to need some work on it to make it fit. This may well be one of those things you buy but then decide it isn't worth the hassle to fit we shall see.View attachment 274827 View attachment 274828 View attachment 274829 View attachment 274830 View attachment 274831
I am leaving the tracks until last as one of them will be getting worked on by the mechanics. I am unsure whether I will put any wiring in the engine bay or drape a tarp over the windscreen and bulk head thus cutting out the need for it.
