Which Glue,
The Smythe Meister
Devon, England
Hi guys,
I'm putting some tiny bits of etch together for my 111,I glued some bits together with Locktite last night, picked it up just now... And it fell apart...
Anyone suggest a glue that will actually keep it stuck please?!!
Any thoughts much appreciated :thumb2:
Loctite CA glue? That ought to have done it.
Solder is obviously the bomb, but CA should work fine for anything non structural. I've started to give the parts a good clean & sanding or scratching with a blade (advice from Scottie if I recall) and it has helped a lot.
I’ve started using this for small bits of etch…I know it’s for canopies, but the bond is less prone to the bond being affected by finger grease.
VMS make a CA specifically for pe. It is reckoned to be flexible and less prone to damage. I've used it and it seems to work. I always slightly roughen the pe and the attachment point to help with adhesion.
I use the VMS flexi stuff and it does the job for me. like Jim I also rough the shiny stuff up a bit…..definitely helps!
I always use Loctite - just make sure the part is free of grease - either wipe with IPA, or pass through a lighter flame
I also find locktite power gel good. A few seconds wriggle room and a slightly flexible bond make it easy to use. Failing that, five minute Devcon is great……
Sounds like a grease problem. As others have said Big structural bit solder them small fiddly bits clean in acetone/thinners/IPA immediately prior to CA, Burnishing helps.
A thin PVA type glue is also good for things that are glued flat on a surface. Gorilla grip glue was my go to. I believe they've gone bust though.
