Partworks Avro Lancaster-Building the wing roots in Part 20
Part 20 includes the following parts for this assembly-
Wing root ribs for the section just aft of the wings,quantity 2.
A flat pack of plastic stringers to add to this assembly.
Another pack of stringers curved up into the magazine which were missing
from Issue 14 for adding to the centre section module.
Stickers for representing the Gas detection panels on the front and rear of
the pilots seat.
Method-
Remove the root ribs carefully from the fret,now take the portion of the
fuselage which is the immediate aft section where it meets the
wings,carefully click these part ribs into place on the protuding portions
of the formers,exercise care as any undue pressure will break the formers
especially the portions that hang down,once this is wriggled into place
check to make sure that it sits flush with the formers,if you are a bit out
with your formers then now is the time it shows up and you may need to trim
a little,next take the assembly outside in the fresh air and flood the
joints with thin cyno where the rib portion meets the formers,there will be
a short puff of smoke as the cyno cures against the dusty wood,thats the
reason for doing this job outside ! I chose cyno for two reasons,one its
strength in this critical area of the model,and also it is easier assembling
dry than fiddling with wet adhesive in this awkward assembly,you will see
what I mean once you offer it up.
Now onto the seats,the Gas detection circles were to detect mustard gas
attacks,any presence of gas would discolour the discs alerting the crew to
danger as they donned their gas masks,the ones provided are vinyl stickers
with yellow print,if you place them onto the dark coloured seats then they
do not show up very well,what I did was to use the outer portion of the disc
as a stencil,I then applied a bit of white paint within the disc,then added
the vinyl sticker,look at the pictures and see the difference it makes as
the luminosity of the white paint shows through.
Stringers-
Next job is to add the stringers to the fuselage module,I wanted a better
method of doing this and decided to make a simple jig which not only makes
the job easier,but allows a much neater job.
To make the jig is simple and you can use it on any parts of the models
fuselage structure during the build,take two pieces of balsa or similar and
butt one onto the end of the jig base ( see pictures for a beter idea of how
it is made ) all you do then is offer the fuselage portion into the
jig,place some weak elastic bands at strategic points to hold the stringers
flush as they are added to the assembly,you can move the module around as
you deal with each stringer until completed.
Allow this to cure out and then with your sanding block go all over the
outside blending everything in,the plastic sands well so do not be afraid to
do the sanding as it makes for a neat job,finish off with fine abrasive
paper,next sand the ends of the formers where they will butt up to the next
pieces eventually.
Now paint this portion with whatever scheme you are using,I have sprayed
mine white primer at this stage only because I need to get some grey primer
and some more Vauxhall Reed green paint to finish off the job.
The full build sequence for the partworks Avro Lancaster project can be found on the Google group build.
