Zimmerit coating
peterairfix
I will be shortly starting my big tiger I am just wondering what to use for zimmerit as I the tools included in the kit any help would be most appreciated
Hi Peter
Have a look at nightshift on Youtube. He does a excellent video on zimm and its on a Tiger
Bob
I like to use a thin layer of putty (from a tube) textured with a saw blade. Work on small areas at a time, because the putty is likely to dry before you get to the end on larger areas, like a hull side.
I used to use Tamiya two part putty.........little longer working life and went on real smooth. Haven't seen it for years, does anyone know if they still make it? Rick H.
Hi Rick
Night Shift uses it for his Tiger. The build is only a year old so should still be available.
A quick question on the zimmerit that was applied to King Tigers,
Would the 'zim' have been applied before or after the 'schurzen' were fitted ?
(I'm currently building a King Tiger that has some of the shurzen removed, and cannot work out if I need to remove the pre-moulded zim to represent steel plate underneath them.)
Zimmerit would be applied “around” everything that’s removable, sheet metal, protrudes, etc. This includes tool brackets but also the side skirts: if you remove one, there should not be Zimmerit underneath.
