- Joined
- Dec 28, 2023
- Messages
- 2,784
- Location
- Swale Kent UK
- First Name
- Peter
An upcoming diorama I will be building will be made from foam board and will have a curved edge.
Once the diorama is complete I will need to cover the curved foam board edge.
The base will be about 300mm in diameter, so the radius will be around 150mm.
What would people recommend as a good material for such a task?
The foam board will be about 10-15mm thick.
It will almost certainly be painted on completion.
Balsa will probably snap!
I could use maybe card of some sort.
I could use some sort of thin plastic card.
I suppose some sort of fabric (maybe a thick stiff fabric) could be used too?
Any other suggestions?
