Rehashing Hurtgen forest diorama
  • rtfoe
    • 9227
    • Richard
    • Shah Alam, Malaysia
    #121
    Originally posted by Stefee
    What kind of witchcraft is this, morphing plastic extrusions into mini persons?
    Seriously though the results of your skilled fettling is wonderful.
    Thanks Stefan...no sorcery involved I swear. Lots of kneading though.
    Today I primed the rest of the figures. I count 25 so far
    Wabble
    • rtfoe
      • 9227
      • Richard
      #122
      Hi Guys,
      Figures mounted ready for painting after zinethalling. So while I prepare my wet pallette, I worked on bringing the tank destroyers up to date...
      Click image for larger version  Name:	IMG_20250428_150824.jpg Views:	0 Size:	458.2 KB ID:	1256405
      The Academy kits I used for the Tank Destroyers was basic and my building wasn't up to today's standards but I'll just keep it simple with minor improvements like the gun sight on the mantlet with it's cover...
      Click image for larger version  Name:	IMG_20250428_222409.jpg Views:	0 Size:	366.4 KB ID:	1256412
      Then removing seam lines from the gun barrel...
      Click image for larger version  Name:	IMG_20250428_151931.jpg Views:	0 Size:	218.1 KB ID:	1256408
      And the gun cradle attachment at the rear which was not on M10s.
      Click image for larger version  Name:	IMG_20250428_151753.jpg Views:	0 Size:	471.3 KB ID:	1256409
      I will probably add stowage to hide the molded on tools.
      Putty filled some bad fits ...
      Click image for larger version  Name:	IMG_20250428_151837.jpg Views:	0 Size:	269.4 KB ID:	1256407
      Open periscope covers and grab handles from bent wire...
      Click image for larger version  Name:	IMG_20250428_222525.jpg Views:	0 Size:	218.9 KB ID:	1256406 Click image for larger version  Name:	IMG_20250428_222330.jpg Views:	0 Size:	464.9 KB ID:	1256410
      That's about it...next to paint it up again and weathered.
      Wabble
      • rtfoe
        • 9227
        • Richard
        #123
        Covers to the periscopes done...
        Decided to add new bolts to the front glacis as well.
        Wabble
        • rtfoe
          • 9227
          • Richard
          #124
          Today I did a first pass of paint with modulation for Shadows and highlights...
          Click image for larger version  Name:	IMG_20250501_015013.jpg Views:	0 Size:	220.9 KB ID:	1256603 Click image for larger version  Name:	IMG_20250501_015052.jpg Views:	0 Size:	220.0 KB ID:	1256604 Click image for larger version  Name:	IMG_20250501_014748.jpg Views:	0 Size:	246.0 KB ID:	1256605 Click image for larger version  Name:	IMG_20250501_014921.jpg Views:	0 Size:	223.7 KB ID:	1256606
          The dark tones were olive drab mixed with black and the highlights olive drab with yellow and dark yellow. All Tamiya acrylics diluted heavily with Mr Levelling thinner. Then filtered with pure thinned olive drab to blend the tones. The heavy dilution didn't require me to mask the stowage. I will pick out any over spray later on.
          I am going to try a winter wash applied roughly and chipping fluid. Fingers crossed it works.
          Wabble
            • 16296
            Great looking paint job. Excellent airbrush skills.
            • rtfoe
              • 9227
              • Richard
              #126
              Thank you kindly Jim. Haven't done modulation for a while so it was fun.
              Wabble
              • scottie3158
                • 14634
                • Holbeach
                #127
                Wabble,
                Some seriously good paint work mate.
                • rtfoe
                  • 9227
                  • Richard
                  #128
                  Wabble,
                  Thanks Scottie, this is just the start of the process and there is 80% more to go. not looking forward to the weathering process but it is necessary to get the look that I want which is just short of overdoing it. 😉
                  Wabble
                  • rtfoe
                    • 9227
                    • Richard
                    #129
                    Hi Guys,
                    I had the bulb in my head switched on and worked out how to distinguish the relieved troops from Patton's armoured division by making them outer perimeter scout patrols of the 101st. So they would have the overall olive drab top to bottom uniform with the baggy trousers pocket extensions. One of them even carries the folding carbine.
                    Lucky for me I only had to convert five figures, then I re zenithalled them. The rest had long coats on.
                    Click image for larger version  Name:	IMG_20250508_154646.jpg Views:	0 Size:	503.1 KB ID:	1257170Added pockets awaiting results painting
                    Click image for larger version  Name:	IMG_20250508_154600.jpg Views:	0 Size:	372.4 KB ID:	1257169
                    Zenithalled... it was a swift job by the tailor.
                    Wabble
                    • scottie3158
                      • 14634
                      • Holbeach
                      #130
                      Nicely done
                      • rtfoe
                        • 9227
                        • Richard
                        #131
                        Nicely done
                        Thanks Scottie, the sculpts always looks nice under a coat of zenithal effects. The most important thing is to make sure all the limbs and posture look right, natural and in scale. The last thing is to add weapon slings using either foil or typewriting paper.
                        Wabble
                          • 16296
                          Totally agree. They look great with the zenithal primer.
                          • rtfoe
                            • 9227
                            • Richard
                            #133
                            Thanks Jim, especially when it picks out all the detail through the highlights.
                            Wabble
                            • rtfoe
                              • 9227
                              • Richard
                              #134
                              I was about to weather my tanks again when I noticed huge gapping holes just behind the sprocket compliments of the battery operated kit that this was. Easily fixed with plastic sheets shaped to fit.
                              Click image for larger version  Name:	IMG_20250518_140810.jpg Views:	0 Size:	496.0 KB ID:	1258090 Click image for larger version  Name:	IMG_20250518_140728.jpg Views:	0 Size:	621.8 KB ID:	1258091
                              Then I tried my hand with chipping fluid for the first time. Applying at first straight from the bottle to the airbrush and it wasn't coming out of the nozzle. I guessed it was too thick so I diluted it with water and sprayed. Then applied the white wash in a cloudy pattern.
                              The results after following the process seen on many YouTube videos turned out pretty okay...
                              Click image for larger version  Name:	IMG_20250518_225111.jpg Views:	0 Size:	278.2 KB ID:	1258092 Click image for larger version  Name:	IMG_20250518_225308.jpg Views:	0 Size:	316.5 KB ID:	1258093 Click image for larger version  Name:	IMG_20250518_225215.jpg Views:	0 Size:	311.1 KB ID:	1258094
                              Still more streaming and rust effects to apply after a pin wash then I will clean up the stowage by repainting them. I didn't bother to mask them as the the over spray was controlled to the minimum.
                              That's all for tonight.
                              Wabble
                              • scottie3158
                                • 14634
                                • Holbeach
                                #135
                                Wabble, very nice mate.
