Rehashing Hurtgen forest diorama
  • rtfoe
    • 9227
    • Richard
    • Shah Alam, Malaysia
    #91
    Hi,
    I've got figures coming out of my ears so I'm laying them aside and taking a look at the tanks.
    I took them apart and totally forgot they were early Academy kits so the details were a bit soft on the bolt heads on the side sponsors.
    I replaced them with sliced tubing that was glued over the existing bolts negating any sanding. Then sliced hexagonal rod was glued in the center...
ID:	1254544 I'm taking whatever stowage that is detachable off for easy repainting. The rest will be masked but before that I s daped whatever mold lines that were visible. I built and painted these almost 30 years ago and it shows. Wish I had time to open the driver's hatch.
    Wabble
    • rtfoe
      • 9227
      • Richard
      #92
      Hi,
      I am reposting this as there was no image on my laptop.
      Hi, I'm adding this group of four and have just modified the arm and hand position of the searching GI from Tamiya. Cranes his head looking low, switched his right arm with a spare from the stash, moved his left arm up and carved enough off his inner shoulder to tilt the arm inwards.
      I have tilted the Germans head to look down at what the GI is searching for. It's been a while since my last Tamiya figure and was amazed with the fit and ease of build compared to the Dragon figures that I am also adding to the Dio.
      Wabble
      • Neil Merryweather
        • Dec 2018
        • 5353
        • London
        #93
        I think this is a bonkers idea, re- hashing an old model, but it's brilliant and you're doing a super job as always Wabble.
        • rtfoe
          • 9227
          • Richard
          #94
          Hi Neil, this is even bonkers...
          Wabble
          • rtfoe
            • 9227
            • Richard
            #95
            Hi,
            More progress on the searching soldier with more padding with putty....
ID:	1255251 Click image for larger version
ID:	1255252 Click image for larger version
            Wabble
            • scottie3158
              • 14635
              • Holbeach
              #96
              Nice work mate.
              • rtfoe
                • 9227
                • Richard
                #97
                Nice work mate.
                Thanks Scottie.
                Here's the bunch of primed and zinethalled ex Tamiya restored figures. They look much more convincing than when they were in a mish mash of the old paint work, putty and different plastic arms, head and legs...
ID:	1255317 Click image for larger version
ID:	1255318 Click image for larger version
ID:	1255319 Click image for larger version
                I will be painting them using Calvin Tans method of light passes of filters after I have highlighted areas with white.
                Wabble
                • rtfoe
                  • 9227
                  • Richard
                  #98
                  I still have another 9 more figures to prime after I have fitted their gear on...
                  Wabble
                  • Airborne01
                    • Mar 2021
                    • 4365
                    • Steve
                    • Essex
                    #99
                    This looks to be the start of something great Wabble!
                    • rtfoe
                      • 9227
                      • Richard
                      #100
                      Hope so Steve, I haven't done a big Dio in a while. Thought it was just an easy task just rehashing but ran away with doing more that I was supposed to.
                      Wabble
                      • Airborne01
                        • Mar 2021
                        • 4365
                        • Steve
                        • Essex
                        #101
                        Wabble
                        And you're surprised ... ?
                          • 19130
                          Excellent work as always Richard. Your usual attention to detail is well to the fore I see
                          • Neil Merryweather
                            • Dec 2018
                            • 5353
                            • London
                            #103
                            Wabble
                            Up to your usual craziness I see, Wabble!
                            (know the feeling)
                              • 16302
                              Excellent work. Those figures look so much more of a unified group now they are primed.
                              • rtfoe
                                • 9227
                                • Richard
                                #105
                                Thanks Steve, Tim, Neil and Jim.
                                Couldn't leave the figures as they were...they would have been frozen without some sought of winter protection. The figures were old and I went crazy with the putty. Now they look more convincing under some primer... cohesive as Jim said that even in a group like I just did they look like they're on a coffee break in between a movie take.
                                Time is getting short so I need to rush a bit. Hope detailing doesn't suffer for that.
                                Wabble
