errors
As the first poster mentioned, I too have found errors in the instructions.
Page 22, magazine 5: The pictures with the lower rear suspension arms suggest that you have the "cranked" (bent) side foward (step 2). It even mentions using the photos as a reference (step 3).
Here's where the error is: In step 5, you have a picture of the rear diff with the pinion gear facing away from you. If you look at it, you can see the cranked or bent side of the suspension arm is also facing away from you. If you read the text - "Take the differential carrier, which you have already made and hold it so that the pinion gear sleeve is pointing away from you and offer up the right hand suspension arm (cranked side foward* so that the races match up with the supports on the differential carrier".
*foward - as in foward away from you and towards the front of the truck (ie wrong), or foward as in towards the viewer?
Even the instructions are wrong. If you look at the photo in step 7, it's wrong there. The photo in step 8 however is correct. So are the pictures on the following page, and they also match up with the exploded diagram on the back of the poster.
