ITS EASY TO MAKE A MISTAKE BUT DAMM FRUSTRATEING
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    HI ALL just finish up in my man cave building a radar motor gear box for my tigers fore mast an I spent nearly 5 hrs on this an as the title says well I look back on this as a really stupid mistake as took this unit in an out of the S/S up to 5 times an stripped it all down as when it was out it worked lovely but when I put it back in it wont work with the mast on pic of the unit as this is a rough built unit just to see if I had got the right gears to make the shaft the right speed as this was scrapped later an built properly when it was right the unit below Click image for larger version
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    ANYWAY the silver colett is fixed onto the gearin Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      an here it is after all the trouble it caused me of the shaft not turning the culprit a small allen scrub screw that I forgot to fit back into the collet to tighten down onto the R-SHAFT an my finger againist it so you can see how small it is
      AAAAAAARRRRGGGGGGGHHHHH
      chrisClick image for larger version
      now have anyone eles made a sily mistake that really gets you ? over to you guys hopefully if anyone will admit it ?
      • Gern
        • 9273
        Far too many to mention Chris - I had a half dozen or so on my Pegasus build alone!
        I'd lose the will to live if I had to write a list of all of them!
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          OK Dave youre exscused but what about all the others ?
          • dave
            • Nov 2012
            • 1844
            • Brussels
            One i will admit too, and i suspect many of those who build aircraft have made this error. I have glued the fuselage together and then looked down to the bench to see the cockpit sitting there.
            • BattleshipBob
              • 6857
              • Bob
              • Cardiff
              Drained oil on a Volvo FH 12 globetrotter, started refilling with 35 l of oil when i noticed the sump plug on the pit oil drainer and a large puddle
              Rhymes with rollocks. Boss not happy bunny nor me as i had to clean it up!!
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                HOORAY a reply well done Dave yes that's a good one I bet the air was blue thanks for your reply
                chris
                AN WOW Bob yes ive done that with my motor bike an rid it about 20 mls an the engine was glowin thanks also for your reply I wonder if any more will come ?
                chris
                • minitnkr
                  • 7652
                  • Dayton, OH USA
                  Spent an hour trying to start my vette forgetting to depress the clutch, allowing ignition to happen. Fired right up after an AH Ha moment.
                  • Mini Me
                    • Jun 2018
                    • 10711
                    Don't you hate that! .........'swhat happens when they design cars to be "Safe and User Friendly" HA!
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      HI PaulE ive got into the habit for yrs now of as soon as I get into my car I push down on the clutch before I try an start as when I was courtin a young lady happened to push my car gear leaver into 1st with her bottom. An I let her go home with her friends as they all came to the disgo togeather an it was dark now well I got in to my banger an just turned the key to start up an the car flew forward straight into the dance hall wall an it smashed all my head lights wow was I angry lol
                      chris
                      • Mr Bowcat
                        • Dec 2016
                        • 4661
                        • Bob
                        • London
                        I had a similar experience the other day Chris. Glued the side armour onto my Abrams, then realised I should have fitted the front return rollers first. Luckily the glue was still a little soft and I managed to bend the sides out without damage, but it was a close call.
                        Si vis pacem, para bellum.
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          HI Bob just as well you dint use super glue then as it would have stuck in seconds then ud have been right in it lol although I find this super glue debonder is very good
                          chris
                            • 19027
                            Back in my railway days It was hard to get useful transfers so I used to hand letter all my stock using process white or process black water based paint. It took ages, and things like tank wagons with curved sides were very hard to get straight and even.....
                            Anyway, once i spent about two hours lettering up a United Dairies wagon. Let it dry, then put on a protective coat of varnish so the water based paint was fixed, and left it overnight to dry before I did the other side....came back to it the next day and found I had a tank wagon perfectly lettered for United Diaries. doh! I don’t think I ever finished it......
                            • Neil Merryweather
                              • Dec 2018
                              • 5273
                              • London
                              My first full-time job was as a sign writer .More than once I spent a great deal of effort fitting all the letters into the available space, only to find I had either missed a letter out or misspelled something , like COMPETITITION.
