Great choice steve , a rarely seen subject for a bust .
					Latest Acquisitions (2021)
 Know a few people who might be interested in a completed one of these (they've got watches to match - Sturmanskie Gagarins, about $300 worth of watch ) )Comment
 A good canvas helps with a good outcome very niceComment
 Yes this will be the one of the last waves. I thought the same about the Spad Tim. I think all three in the top pic were made in GB.Comment
 Put in an offer for this and got it.
 [ATTACH]423798[/ATTACH]
 It was marked as used but was in the box like new.
 Andy.Attached FilesComment
	 Guest Guest
 Hi Chris
 I am sure you have made a good choice and the Iwata will serve you well.
 The nozzle is very tiny and the screw threads are delicate. You will rarely need to remove it but unscrew it carefully over a tray and put it back gently so as not to cross thread it and don't over tighten it.Comment
	 Guest Guest
 Thanks Tim!
 I have to point out that this is the first time I have bought an airbrush from new! I just tried it out and my goodness what a difference! This is so responsive and accurate, the coverage is amazing and the level of control you have means I will have to unlearn some of my bad habits.
 I don't know why I was worried about needle size; I was able to paint a 1mm wide line with no effort. I was lucky if I could get a 10mm line with the old one!Comment
 Hi all
 So these paints have arrived over the last few days and so I can now get on with painting my DAK figures.
 And no I'm not taking up golf.....I saw Tim used them as stands for painting his 1/72 figures and thought genius idea. I've tried to be a bit environmentally friendly by getting wooden ones.
 ATB
 [ATTACH]423875[/ATTACH]Attached FilesComment
 Chris
 Take Jim's overtightening warning very seriously.......I sheared mine off using the supplied spanner......cost me £40 to replace......AB only cost £100......
 Get one of the Iwata Nozzle wrenches - they work with any similar nozzle type......I'm not saying it's impossible to overtighten with them but it takes a lot more effort.
 ATB
	 Guest Guest
 I've done that too, lucky it was just a cheapy a.b.Chris
 ATB
 [ATTACH=CONFIG]n1151812[/ATTACH]Comment
