Decal removal
  • The Smythe Meister
    • Jan 2019
    • 6248
    Decal removal
    Mornin'
    As the title suggests I'm after a proven method for getting a decal off a model, without causing too much damage to the surface beneath.
    Any ideas would be much appreciated chaps
    • 16295
    I can't help Andy but I imagine that if you've put a coat of sealing varnish over the decal it becomes very much harder. I'll be interested in the replies.
      With decals that adhere well, the only reliable method I’ve so far found is scraping with a knife … but that kind of goes against the “without causing too much damage” requirement
        • Jan 2019
        • 6248
        Hi Jim,
        I haven't used varnish over it yet.... Only Micro set,so fingers crossed!
          • Jan 2019
          • 6248
          Originally posted by Jakko
          With decals that adhere well, the only reliable method I’ve so far found is scraping with a knife … but that kind of goes against the “without causing too much damage” requirement :sad:
          Cheers Jakko,
          It might come to that if no other method comes to light......
          ..... The bloody thing has to come off one way or another!!
          • Allen Dewire
            • 4741
            • Allen
            • Bamberg
            According to the bottle, Mr. Smiff, Micro Set can also be used for decal removal. Might be worth a try Andy...
            • PaulTRose
              • Jun 2013
              • 7247
              • Tattooine
              i was going to say try plenty of microset to soften it up
              Per Ardua
                • Jan 2019
                • 6248
                I did try that last night Allen but the thing wouldn't budge apart from "scrunching" up a bit
                  • Jan 2019
                  • 6248
                  Sorry Paul,crossed posts there!
                  Thanks for that mate.
                  • Airborne01
                    • Mar 2021
                    • 4360
                    • Steve
                    • Essex
                    Hi Jim,
                    Copious amounts of Micro Sol will soften and wrinkle the offending beast allowing careful removal with a blade!
                    • Allen Dewire
                      • 4741
                      • Allen
                      • Bamberg
                      Have you tried using a pin to gently prick the decal several times and then brushing more Micro Set on it? The only other idea would be sandblasting it off, but that is rather extreme...
                        • Jan 2019
                        • 6248
                        Cheers Steve,
                        Looks like I'll be hosting it down with Micro Sol this afternoon then
                          • Jan 2019
                          • 6248
                          ..... the more I think about it,the more appealing sandblasting the ruddy thing gets!!
                          • PaulTRose
                            • Jun 2013
                            • 7247
                            • Tattooine
                            Per Ardua
                              • Jan 2019
                              • 6248
                              That's excellent Paul,
                              I'll give that a bash later and let you know how it went with some "before and after" pics.
                              Thanks for that!!
