Decal removal
  • KarlW
    • Jul 2020
    • 1522
    #16
    Bin the kit, buy a new one, genuine excuse for doing so........
    • The Smythe Meister
      • Jan 2019
      • 6248
      #17
      Get behind me Satan....
      ..... Spent enough on this hobby the past few days as it is you bad,bad man!!
      • KarlW
        • Jul 2020
        • 1522
        #18
        Yeah, like you're not already thinking it..........."Pet I bought the wrong colour of green for this model, so now i need to buy a model that is this green so I don't waste the paint."...............
          • 16299
          Invest in one of these - that will shift the b*****s
          • KarlW
            • Jul 2020
            • 1522
            #20
            [ATTACH=CONFIG]n1187325[/ATTACH]
            Approved.
            • PaulTRose
              • Jun 2013
              • 7252
              • Tattooine
              #21
              ..... the more I think about it,the more appealing sandblasting the ruddy thing gets!!
              there ya go......not that expensive :smiling6:
              hope the link works
              Per Ardua
                • 18302
                Probably far to late but send me a couple of those pasties and I will tell you how to get the decal off.....
                No ok .
                MICRO SOL. failing that vinegar...
                  • 19130
                  Don’t know about decal removal, but that’s one of the best DIY tools I’ve ever bought……just superb!
                  • Toon Meister
                    • Feb 2022
                    • 80
                    #24
                    The best way to remove waterslide decals without damaging the paint is with vinegar. You may have to saturate the decal a few times, but it will not affect the paint.
                      • Jan 2019
                      • 6248
                      #25
                      Thanks for that,
                      Nothing else has worked so far,so I'll give that a go...... I'm guessing you mean White vinegar?!!
                        • 19130
                        Thanks for that,
                        Weird isn’t it. Decals have water based adhesive sticking them on the backing paper, but that turns into a relative of araldite when you try to get them off the model again….just out of interest, what is the underlying paint Andy?
                        Not tried this, so take it with a pinch of salt……strikes me that white vinegar will need a spot of washing up liquid added to it so you can reduce the surface tension of the liquid and allow it to properly wet out and penetrate the decal. Might need several applications as well. It you get any crinkling, scratch off the soft part of the decal with a chisel edged cocktail stick. The more “edges” the solution has to work with the better it will penetrate. I don’t know what Micro Sol is made from, but it smells of acetic acid (vinegar) so is probably quite similar.
                        • stillp
                          • 8308
                          • Pete
                          • Rugby
                          #27
                          Might also be worth warming the vinegar a little. Not too much so it softens the plastic though!
                            • Jan 2019
                            • 6248
                            #28
                            Hi Tim,
                            Yes,it is strange that these things are so stubborn to remove!
                            The paint underneath is Tamiya silver leaf,I had no luck at all with the Sol/set idea,so the white vinegar method will be my next sortie!
                              • Jan 2019
                              • 6248
                              #29
                              Cheers Pete,
                              I shall do that
