How long does PVA glue take to go off (in normal conditions)? I used some last night to put some weights into my TA-154 and it's still not solid. Any ideas guys?
PVA Glue
It can take an age an is dependant on external conditions AS WELL as how big a blob you've got, i'm guessing you've got a fair glob of it around the weights?
A faster alternative is Epoxy, you can get it in 5 min, 30 min or longer and that's a chemical reaction with the hardener so it matters not if it's a dribble or a blob -
It's a waiting game unfortunately, just keep an eye unti it starts to become translucent. The thicker the blob, the longer the drying timeComment
Guest -
As has been said, it all depends on how thick the application is. A very thick blob could take a few days but don't worry, uit will eventually set. The trouble is that PVA dries so is dependent on the ratio of surface area to volume, whereas epoxy is a chemical reaction and is therefore independent of surface area.Comment
