[quote name=wmar1967
' date=' post: 180294, member: 24273]Thank you.
For those that use enamels, another 5 questions!
1. What is the best/most comprehensive range you use? I've always used Humbrol and sometimes Revell
2. Where's the best shop to get all your modelling paints...using Amazon often turns out expensive in postage!
3. How do you stop the tins that aren't used so often from drying out/forming a rubbery layer on top
4. How do you know the consistency/mix ratio for enamel to thinners?
5. Do you use white spirits or thinners (for cleaning and thinning)?
I am really done now today - thank you all for taking the time to answer. You've likely all replied to these questions a thousand times before.
1 You've already got Humbrol. They have a good range and with the return of manufacturing to the UK the recent quality issues will hopefully improve. For specialist colours I use White Ensign Colourcoats. I can't praise these highly enough. They are the best paints of any type that I have used.
2 You can order Humbrol paints from the Humbrol web site or try other on line model shops that stock them, you might save a bob or two.
The Colourcoats I order directly from White Ensign.
https://www.whiteensignmodels.com/c/Colourcoats Paint/640/1/
3 Good housekeeping! You must clean the top of the tinlet and lid (if necessary) before putting the lid back on. Make sure you really push the lid on to make an airtight seal. I have some paints still useable after several years.
4 This is tricky and you will really need to experiment to find out what works for you and your set up. Different paints, even from the same manufacturer, also vary. Most enamels will fall in the range of 60/40 to 40/60 paint to thinners. That equates to about 50/50 on average. You will often see people suggesting the consistency of milk which is also a bit vague. Another tip is to drag some paint up the side of the cup with a cocktail stick or brush handle, it should run back but coat the cup.
There is I'm afraid no substitute for practice, however, in my experience enamels can be thinned a lot more approximately than acrylics. That is they will spray and work well in a larger window.
5 I use white spirits for thinning and cleaning. My current bottle is from Wicks (£3.75 for 2l which will last ages). I do use cellulose thinners from Halfords for deep cleaning but this is not suitable for all airbrushes.
