Aeroplast BM 13-24 Katyusha in 1/35 scale.
  • Si Benson
    • 3572
    #136
    Evening John,
    Been watching this come together from the cheap seats and I’m suitably impressed. The smoke trails from the launcher looks totally convincing….top job mate :thumb2:
      Originally posted by Si Benson
      Evening John,
      Thanks Si , tried to email you, have you changed your address ?
      • Si Benson
        • 3572
        #138
        No not changed address :thinking:
          Must be me then, thanks Si.
            Greetings all.
            Doesn't time fly when your painting bricks walls.Spent a couple of happy hrs just doing that.
            Also painted the frame , gas bottles,engine and the drums.
            Base has been sanded as well .
ID:	1162378Click image for larger version
ID:	1162379Click image for larger version
ID:	1162380Click image for larger version
            Now reports of Aliens, yes Aliens , they have been seen on one of the finished kits.
ID:	1162382Click image for larger version
            Investigations are underway and a likely suspect has been named and will be interviewed soon.
            Thanks for looking in.
            Comments always welcome.
            Dzhon.
            • Steve Jones
              • 6615
              #141
              You have been busy JR. Wonderful work my friend
              • adt70hk
                • Sep 2019
                • 10554
                #142
                Loving the base and building John!
                ATB.
                • Mini Me
                  • Jun 2018
                  • 10711
                  #143
                  Jus......Bootyful JR :thumb2: Rick H.
                    Thank you Steve, I've got some Humbrol Enamel on order as well ! Should have painted the base and walls with that first( 2 thinned coats ) They would have made the foam board harder. Resulting in the acrylics not soaking in as much .Always something to learn .
                    ATB.
                    Cheers Andrew, using those paints that we mentioned, even went over the " steel work " with them, very impressed with the depth .
                    Cheers buddy , hipity hop
                    • Isitme
                      • Nov 2020
                      • 795
                      #145
                      Oh thank you person of great modelling skills. Yes younger than you has done very well .
                      Here is a gas bottle for you .[ATTACH alt="2021_8.jpg"]437062[/ATTACH]:smiling2: Took hrs to put together.[ATTACH alt="2021_12.jpg"]437067[/ATTACH]Oh and a barrel , 4 parts so took me 6 times as long:upside:
                      Thanks Paul, it came out better than I could of hoped.
                      So you have worked out how to get out of the handcuffs, corset and fishnet stockings while suspended above the wardrobe, tell SWMBO she must try harder......
                        No ! :smiling5::smiling5::smiling5::smiling5::smiling5:
                          To day with the weather as bad as it could be without snow the garden was left.
                          However I did manage to mark out some bricks, cut them out with a few intact and damaged.
                          Then mixed up some grey paint and mixed them all in .
                          Just taken over an hr to separate and leave then to dry, before applying paint to some is the faces.
                            Hello lovers of bricks and stone sets.Yes another update into the world of bricks and stone.
                            The loose bricks have had another coat of paint.
                            More detailing to follow on those .
                            The wall has had the window fitted and been painted both sides.
                            And the base stone sets have had more paint on them.
                            Next is the mortar line in the bricks.
                            Dzhon.
                              • 16312
                              Hi John
                              All looking very good. Brick colouring is spot on. What are the bricks made of? I seem to remember someone on the old forum used cork sheet cutup.
                              • Mark1
                                • Apr 2021
                                • 4156
                                #150
                                Nice work,very realistic,as Jim said the colouring is spot on.
