Aeroplast BM 13-24 Katyusha in 1/35 scale.
    Evening all .
    Following some pm's between myself and Dude1 aka Allen nearly Retired of Bamburg
    A joint effort has resulted in this .
ID:	1162085Click image for larger version
    Took some time to find out how much of the web was required, very little , and much less than you would think .
    Teasing it out was fun, as you soon ended with single threads stuck to hands , jumper and even on my glasses !
    Applying the pigment by a largish flat brush was soon given up when I found that rubbing the web in pigment that was on the paper gave a better coverage. It was only when doing the black and grey towards the end of the trail that it was just scattered on.
    Once done I gave it a spray of Hair Spray , mainly just to keep the pigment in place .
    Pleased that there is a little red showing through from the paint on the two part glue holding the wire on .We decided that although the photos that I found showed very little black smoke at the onset of the launch some would look better .
    The base foam board has been glued in place , so while the model sits well out of the way the stone sets can be imprinted.
    Going to show part of a steel factory roof support left after a direct hit, so only a small section of brickwork and maybe a lone window frame with the remains of the glass .
    Hopefully tomorrow after another trip to the recycling center with yet more discarded garden and shed finds I can carry on with the base .
    Thanks for looking in .
    Dzhon.
      I like it, it looks really good
      • outrunner
        • Apr 2019
        • 2420
        #108
        Great job with the web stuff John, I like it.
        Andy.
          • 16311
          Hi John
          Well I would call that a great success. Well done to you both. Getting such a realistic look is quite an achievement.
          • Mark1
            • Apr 2021
            • 4156
            #110
            Great idea John, the web works well.
              • 19134
              That looks really cool John. Excellent!
              • Mini Me
                • Jun 2018
                • 10711
                #112
                JR, you have done it again! Not only a masterful job of recreating rocket exhaust but also a newly discovered "hair"-do for Matron in the process....I should think your talents will be in demand at the local beauty salon. Tip O' the Hat to you my friend..........you never cease to amaze me. Along with the others, I await further developments. Also Kudos to Dude 1 for not allowing you to employ too much "fire" in your rocketry....we all know how that could turn out!! :tongue-out3: :tongue-out2::tongue-out::thumb2::thumb2::thumb2: Rick H.
                • Neil Merryweather
                  • Dec 2018
                  • 5354
                  • London
                  #113
                  Looking absolutely superb, John. On target for another 'Dog's', I would say.( I know you can't really award it to yourself, but I am sure the committee will make an exception)
                  Maybe we could get a new emoji...?
                  • scottie3158
                    • 14638
                    • Holbeach
                    #114
                    John/Allen,
                    That has turned out really well. Very convincing.
                      Originally posted by Jakko
                      I like it, it looks really good :smiling3:
                      Thanks Jakko
                      Very true indeed my friend, this time real fire was banned. Actually I do cut Managements hair and mine, not been refused entry anywhere yet so must be ok..
                      Thank you Neil, the rules are rules , no family members of any one working for the estates is allowed. I'm sure you could come up with something fitting, like ash !:upside:
                      John/Allen,
                      On behalf of my technical advisor and my self thank you Paul.
                        Today saw the base foam board worked on, I found a window frame that I had made some time ago, and along with some spare brick work.
                        Yesterday I started the steel work, cut it down as it didn't need to be that high.
                        First coat of black wash has been applied, tomorrow when dry it can be lightly sanded back.
ID:	1162137Click image for larger version
                        Along with some gas bottles, 3 fuel drums, an engine, to have inside mixed in with the debris.
                        Thanks for looking in, comments as usual please, hints or dam right abuse:upside:
                        Dzhon.
                        • Steve Jones
                          • 6615
                          #117
                          Cracking work my friend. Looking forward to seeing it all come together
                            Thanks Steve, what on earth are those "things " on recent acquisitions page, concerned about seeing those. :smiling3:
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #119
                              Just beautiful JR, Yes......seeing you efforts of the other day brought to mind Mrs. Slocomb from the old sitcom "Are you Being Served"? She was the master of odd hair back then, Now it seems to be the "norm"......go figure! Cheers, Rick H.
                              • adt70hk
                                • Sep 2019
                                • 10554
                                #120
                                Love the updated smoke effect. That really has turned out beautifully. And as you say good to still be able to see a bit of the flame through it too.
                                Great work.
                                ATB.
