Aeroplast BM 13-24 Katyusha in 1/35 scale.
    • 16192
    Hi John
    Looking forward to seeing the base come together.
      Originally posted by Mini Me
      Just beautiful JR, Yes......seeing you efforts of the other day brought to mind Mrs. Slocomb from the old sitcom "Are you Being Served"? She was the master of odd hair back then, Now it seems to be the "norm"......go figure! Cheers, Rick H.
      Hi Rick, arg Mrs Slocomb, a distant relative of Matron I believe. Very funny series.
      Originally posted by adt70hk
      Love the updated smoke effect. That really has turned out beautifully. And as you say good to still be able to see a bit of the flame through it too.
      Great work.
      ATB.
      Thanks Andrew, I was pleased to see that could be seen, thought all that work would be lost .
        Originally posted by Jim R
        Hi John
        Thanks Jim.:thumb2:
        • rtfoe
          • 9208
          • Richard
          • Shah Alam, Malaysia
          #124
          Evening all .
          Following some pm's between myself and Dude1 aka Allen nearly Retired of Bamburg
          A joint effort has resulted in this .
          [ATTACH=CONFIG]n1162085[/ATTACH][ATTACH=CONFIG]n1162086[/ATTACH]
          Took some time to find out how much of the web was required, very little , and much less than you would think .
          Teasing it out was fun, as you soon ended with single threads stuck to hands , jumper and even on my glasses !
          Applying the pigment by a largish flat brush was soon given up when I found that rubbing the web in pigment that was on the paper gave a better coverage. It was only when doing the black and grey towards the end of the trail that it was just scattered on.
          Once done I gave it a spray of Hair Spray , mainly just to keep the pigment in place .
          Pleased that there is a little red showing through from the paint on the two part glue holding the wire on .We decided that although the photos that I found showed very little black smoke at the onset of the launch some would look better .
          The base foam board has been glued in place , so while the model sits well out of the way the stone sets can be imprinted.
          Going to show part of a steel factory roof support left after a direct hit, so only a small section of brickwork and maybe a lone window frame with the remains of the glass .
          Hopefully tomorrow after another trip to the recycling center with yet more discarded garden and shed finds I can carry on with the base .
          Thanks for looking in .
          Dzhon.
          John...you had to show your pyrotechnic skills with fibre did you...it worked and looks great.
          The dio is coming together too.
            Thanks Richard, there may come the day where I can get everything in , from Snow, Wind and Fire ( What a band ) and some water !
            • rtfoe
              • 9208
              • Richard
              #126
              Yup... It's Written In The Stone. They're more down to Earth than Snow. :smiling3:
              • Isitme
                • Nov 2020
                • 795
                #127
                JR,
                Well done with sorting out the smoke problem with assistance from Youngerthanme, now looking forward to the finished item.
                Hip hop along the way....
                • minitnkr
                  • 7785
                  • Dayton, OH USA
                  #128
                  Latest smoke & fire looks perfect. Great work.
                    Originally posted by Isitme
                    JR,
                    Oh thank you person of great modelling skills. Yes younger than you has done very well .
                    Here is a gas bottle for you .[ATTACH alt="2021_8.jpg"]437062[/ATTACH]:smiling2: Took hrs to put together.Oh and a barrel , 4 parts so took me 6 times as long:upside:
                    Thanks Paul, it came out better than I could of hoped.
                      Not content with the reused wall I decided to make a new section. Two reasons,, first I didn't have enough for debris and second having one chance of getting the brick work to look all the same.
                      Think I have about enough, the cut out sections can fall into the street, giving enough gap for the internals still to be seen.
ID:	1162219Click image for larger version
                      That,s it for tonight, thanks for the comments.
                      Dzhon.
                      • rtfoe
                        • 9208
                        • Richard
                        #131
                        Ooh!...Stepping on...stepping on broken glass...Eurythmics. :smiling3: There's one thing I am uncomfortable with is broken glass...when cleaning up shards from the floor expecting some piercing my feet as we don't wear footwear in the house.
                        Nicely shattered John.
                          Thanks. I agree,even one of these off cuts can stick in the end of your finger Richard:nerd:
                            Originally posted by outrunner
                            Great job with the web stuff John, I like it.
                            Andy.
                            Sorry I missed you there Andy, than you.
                            Hi John
                            Well I would call that a great success. Well done to you both. Getting such a realistic look is quite an achievement.
                            Thanks Jim.
                            Originally posted by Mark1
                            Great idea John, the web works well.
                            Thanks Mark.
                            That looks really cool John. Excellent!
                            Cheers Tim
                              Actually …
                              Looking good, John!
                              • rtfoe
                                • 9208
                                • Richard
                                #135
                                Originally posted by Jakko
                                Actually … :smiling3:
                                Looking good, John!
                                Developing the John syndrom. :smiling6:
