Modified Jeep
  • scottie3158
    • 14634
    • Holbeach
    Modified Jeep
    Hi All, I came across a picture on line a while back and thought it would be good to try and replicate it. There are only one or two pictures I can find, so there will be a lot of guess work and poetic licence.
    It shows a vehicle modified into a mobile work station, used by the Australian 1st Div in Burma. I will be using the Tamyia Jeep as the base.
    This will push my scratchery to the limits but it should be fun.
    cheers
    Scottie
  • PaulTRose
    • Jun 2013
    • 7252
    • Tattooine
    This should be good
    Per Ardua
    • scottie3158
      scottie3158 commented
      Editing a comment
      I hope you wont be disappointed.
  • rtfoe
    • 9227
    • Richard
    • Shah Alam, Malaysia
    Only the Aussies can come up with such a field modification...interesting. If anybody can do it it's you Scottie. Pulling up a chair for this. Any tea and biscuits?
    Wabble
    • scottie3158
      Editing a comment
      Good t have you along mate. You could and I may well do build a raft of Jeeps with modifications. Always tea and biscuits mate and preference?
  • HAWKERHUNTER
    • Feb 2012
    • 2074
    • Steve
    • Halifax, West Yorks.
    I will be following along Paul. This should be fun.
    • scottie3158
      Editing a comment
      Steve, pull up a chair mate. Fingers crossed.
    • 16299
    A unique idea. I'm sure your scratchery skills are up to the job.
    • scottie3158
      Editing a comment
      Hi Jim, I hope so I would like to have a fair crack at it.
  • minitnkr
    • 7806
    • Dayton, OH USA
    ...at some point the Jeep incorporated a power take-off. I'm aware of many uses post-war, but am unsure when it was incorporated. I imagine it would require another stick to engage/disengage. Neat idea.
    • scottie3158
      Editing a comment
      Paul, the transfer box in the kit while being very simplistic does have the PTO part. And the cab floor had the moulded cover that could be removed. As to the PTO lever that's a good point I will have to check the pictures.
  • Richard48
    • 2245
    • Richard
    • Clacton on Sea
    Now that is different Paul.Chair pulled up for this mate.Im wondering if say Miniart might maybe have some factory or engineering type equipment in their range.But thats my way out being lazy and not so au fait with scratchbuilding like yourself and Mike.
    • scottie3158
      Editing a comment
      Richard, I may have a look later but I'm hoping that I have enough in the odds and sods box for the moment.
  • scottie3158
    • 14634
    • Holbeach
    Work has started. I have removed or filled the moulded parts of the tub ready for the scratch work and PE later. Referring to Pauls previous post. One item in the PE was the access cover plate for the PTO. So I have opened it up and drilled the four bolt holes around the edge.
    cheers
    Scottie
    • Airborne01
      • Mar 2021
      • 4361
      • Steve
      • Essex
      Just stumbled on to this Scottie, do you ever sleep? Looking forward to this result as I do with all your other outcomes!
      • scottie3158
        Editing a comment
        Hi Steve, thanks mate. I try and get a few hours lol.
    • JayCee
      • Aug 2019
      • 1154
      So, you are off on another epic bout of scratchery. This should keep you busy for a while. Will follow avidly.
      John.
      • scottie3158
        Editing a comment
        John, this one is really going to push me, hopefully it will turn out ok.
      • 22983
      Just caught this one in time Paul, a nice start and I’m looking forward to seeing more of your work on this.
      • scottie3158
        Editing a comment
        Cheers Ian,, good to have you along.
    • scottie3158
      • 14634
      • Holbeach
      I have had a go at making the generator. This will be driven by a belt attached to the transfer box later. It still needs a final clean up.
      cheers
      Scottie
        papa 695
        commented
        Editing a comment
        Nice work
    • minitnkr
      • 7806
      • Dayton, OH USA
      Jeep PTO. This is Spicer type, the other type(?)has a bent shifter.
      Click image for larger version  Name:	jeep pto.jpg Views:	0 Size:	16.5 KB ID:	1259608
      Photo for illustration only.
      • scottie3158
        Editing a comment
        Paul, is this in addition to the other three selectors. which I would imagine are gears, high/low range and 2/4 wheel drive
      • 16299
      You've generated a great looking generator
      • scottie3158
        Editing a comment
        haha I like what you did there
    • rtfoe
      • 9227
      • Richard
      cheers
      Scottie
      Had to have a magnifyer attached to another magnifyer to see this...looks the beezness even without paint.👍
      Wabble
      • scottie3158
        Editing a comment
        cheers mate it was fun making it lol.
