Scotties NAG
  • scottie3158
    • 14634
    • Holbeach
    Scotties NAG
    This is next up on the bench it is the AFV offering of the Bussing NAG truck with the Bilstein 3T crane. I have built a couple of AFV kits before and they normally go together quite well.
    The box contains 15 tan coloured sprues, the detail looks ok at first glance with a little flash but nasty raised injector marks especially on the inside of the chassis rails. In the box is also a clear sprue. one small sheet of etch 7 vinyl tyres I may go for some resin ones later, 1 length of black cotton and 1 sheet of decals giving 3 options.
ID:	1262658 Click image for larger version
ID:	1262660 Click image for larger version
ID:	1262661 Click image for larger version
ID:	1262662 Click image for larger version
    The detail is not bad but it can be improved.
    Hope you can join me along the way.
    Scottie
  • Airborne01
    • Mar 2021
    • 4361
    • Steve
    • Essex
    Joining you willingly mate; I built this a year or two back and it was very well received. Keep an eye out for vague location marks on the chassis - the fit is millimetre perfect! (Enjoyable build though!)
    • scottie3158
      scottie3158 commented
      Editing a comment
      Cheers Steve for the heads up, good to have you along.
  • PaulTRose
    • Jun 2013
    • 7252
    • Tattooine
    This looks interesting
    Per Ardua
    • scottie3158
      Editing a comment
      Paul, I hope I can keep it interesting mate.
    • 16299
    Right up your street. AFV kits often have many little parts and this looks typical. I have no doubt you'll do it proud.
    • scottie3158
      Editing a comment
      Jim, thanks mate good to have you along.
  • Steven000
    • Aug 2018
    • 2947
    • Steven
    • Belgium
    Nice one Scottie, looking forward to your build, cheers
    • scottie3158
      Editing a comment
      Thanks Steven, good to see you.
  • Neil Merryweather
    • Dec 2018
    • 5351
    • London
    Another one to watch and drool over! You're a machine!
    • scottie3158
      Editing a comment
      Haha thank mate.
  • Geoffers
    • Jan 2017
    • 2177
    • Geoff
    That look interesting Scottie, good luck with the build 👍
    Geoff.
    • scottie3158
      Editing a comment
      Thanks Geoff, I have wanted to build one of these for a while now.
  • Richard48
    • 2245
    • Richard
    • Clacton on Sea
    Scottie
    When i first saw NAG i thought blimey Paul must be doing something equestrian!!!.How wrong was i DOH
    • scottie3158
      Editing a comment
      ha ha maybe one day mate.
  • stillp
    • 8308
    • Pete
    • Rugby
    If you need any NAG expertise, my wife's an expert!
    • scottie3158
      Editing a comment
      I guess you typed this when she was out of the room
  • stillp
    • 8308
    • Pete
    • Rugby
    "I guess you typed this when she was out of the room "
    Of course, I'm not as brave as Miko!
    • Richard48
      • 2245
      • Richard
      • Clacton on Sea
      Scottie
      I reckon it be great to do a Cent or Chieftain dual build sonetime mate.
      • Richard48
        • 2245
        • Richard
        • Clacton on Sea
        Originally posted by Richard48
        I reckon it be great to do a Cent or Chieftain dual build sometime mate.
        • scottie3158
          Editing a comment
          Now that sounds like a plan mate.
      • scottie3158
        • 14634
        • Holbeach
        The build has started as per usual with lorries with the chassis. It went together well after the raised injector marks had been removed. Despite the fact I can find no pictures of the chassis I will add just for effect some air/brake lines. You really have to figure out somethings the exhaust for example. There is a choice of length. In this case it shows the short one. However when used the bracket shown in the instructions doesn't fit where shown. Then the instructions show in the next step the long exhaust fitted. I would imagine that that instruction is reused from another version of the truck.
        cheers
        Scottie
        • JayCee
          • Aug 2019
          • 1154
          Hi, paul, just joined this. "detail is good, but can be improved" I guess this means the usual 95% Scottie's work and 5% kit.
          Looking forward to the magic.
          John.
          • scottie3158
            Editing a comment
            Cheers John, hopefully it won't be that much this time. Glad your looking in.
        • scottie3158
          • 14634
          • Holbeach
          One place where I think kit manufactures can really improve is suspension detail. The spring hangers are nearly always moulded as solid blocks and for me it ruins the overall look. So I like to improve them where I can.
          The kit offering of one of the rear springs
          and what hopefully is an improvement
          And finally for today the fuel tank has had the moulded pipework and straps replaced with wire and pewter strip.
          cheers
          Scottie
          • Steven000
            Steven000 commented
            Editing a comment
            Lovely extra details Scottie, cheers
