Scotties NAG
  • stillp
    • 8309
    • Pete
    • Rugby
    #31
    Originally posted by Jim R
    It's also rare for instructions to be amended when issues are flagged up.
    Shocking, when they're all generated electronically. If they were still typeset you could understand a reluctance to correct them but it shouldn't take long to amend a pdf or dtp file.
    • scottie3158
      scottie3158 commented
      Editing a comment
      Like most things today, the easier things get to do the less people bother lol.
  • HAWKERHUNTER
    • Feb 2012
    • 2074
    • Steve
    • Halifax, West Yorks.
    #32
    Fantastic work Paul. Looks very lifelike indeed.
    • scottie3158
      Editing a comment
      Thanks Steve, appreciate the comment.
  • JayCee
    • Aug 2019
    • 1154
    #33
    Hi, Paul, The engine is a work of art, as usual. It looks even better under paint. Looking forward to the rest !
    John.
    • scottie3158
      Editing a comment
      Thank you John, I still don't know if I will have the bonnet open yet, but thought I better add a little in case I do.
  • scottie3158
    • 14635
    • Holbeach
    #34
    Next up is the cab. I have added a bit of wiring but it is only for effect. And some missing rivet detail to the bulkhead.
    I will revisit the dials.
    I wanted the cab to look lived in but not overly dirty. Good old sweet wrappers for the leather effect on the seats.
    cheers
    Scottie
    • stillp
      • 8309
      • Pete
      • Rugby
      #35
      " I have added a bit of wiring but it is only for effect." Only for effect? You mean it doesn't actually work? I'm shocked.
      • scottie3158
        Editing a comment
        Haha thanks mate.
    • scottie3158
      • 14635
      • Holbeach
      #36
      The bulkhead has had some pipework added. and been fitted to the chassis.
      cheers
      Scottie
      • minitnkr
        • 7806
        • Dayton, OH USA
        #37
        Love the plumbing, but the chair is amazing.
        • scottie3158
          Editing a comment
          Thank you Paul.
      • scottie3158
        • 14635
        • Holbeach
        #38
        One nice touch with this kit is the louvres in the bonnet sides. They are nicely moulded allowing the openings to be seen on the inner face. The down side is the catches are moulded on, so I thought they could be improved a little.
        cheers
        Scottie
        • HAWKERHUNTER
          • Feb 2012
          • 2074
          • Steve
          #39
          What a difference Scottie.
            • 16301
            Amazing detailing.
          • scottie3158
            • 14635
            • Holbeach
            #41
            The rest of the bonnet is assembled.
            One thing this kit does suffer from is huge ejector marks. Can anyone recommend a descent filler I bought some AK green stuff but it's useless. It either peels out of shallow fills, it doesn't go hard and it shrinks.
            cheers
            Scottie
            • Nicko
              Nicko commented
              Editing a comment
              Love that bonnet hinge Scottie.
              For the ejector marks, could you glue in some punched discs?
              Nick
            • stillp
              stillp commented
              Editing a comment
              I like the Humbrol filler. Sands well, sticks well.
          • scottie3158
            • 14635
            • Holbeach
            #42
            Nick, that's what I normally do but these were not that deep so just decided to go for the filler.
            • HAWKERHUNTER
              • Feb 2012
              • 2074
              • Steve
              #43
              I just use Plasto Paul. I hate the green stuff. Even the plasto does shrink a bit depending on how much you use but I just top up any shrinkage cracks with a liquid plastic putty and then sand.
              • scottie3158
                Editing a comment
                Thanks Steve, I may give a tube of that a go. I used to use the squadron green stuff which was excellent then they changed the formula and it is a s bad as the AK stuff.
            • scottie3158
              • 14635
              • Holbeach
              #44
              I have been working on the storage locker. had a root round in the bits box and put some clutter in. The missing panels will be added when nearly finished so I don't keep knocking them off.
              cheers
              Scottie
              • scottie3158
                • 14635
                • Holbeach
                #45
                Work has continued on the chassis.
                the flatbed is the next step. There are four wheel chocs stored under the end of the bed. The kit ones were rather simplistic so I have replaced them. One has the chocs in place the other is empty as I will have them in place under the wheel later on. The empty one I have left a bit battered due to wear and tear.
ID:	1265421 Click image for larger version
                Finally the locker detail was replaced.
                cheers
                Scottie
