A look in the box.
  • outrunner
    • Apr 2019
    • 2420
    A look in the box.
    Looking at the movable chain for my upcoming 1/6 Honda CRF 1000 Africa Twin build, this should be interesting.
    Four sprues with 70 odd parts on each.
    And a steel roller for every pin.
    At least Tamiya give you a jig to build chain sections on and a tool to press the side link plates on which should make it a bit easier. I will need to pay attention though as the holes in the plates are tapered so must be fitted correctly.
    Andy.
    • 16165
    Looks fun. Nothing is glued? Just a taper fit? It will be interesting to see how you get on and how flexible and secure the finished chain is.
    • Mark1
      • Apr 2021
      • 4156
      That will keep you busy for a while! That jig should make life a lot easier though.
      • Mickc1440
        • 4849
        Good luck
          Originally posted by Jim R
          Nothing is glued?
          The sprue says it’s ABS, so it can’t be glued at all with most normal model cement.
            • 19104
            Plastruct ABS solvent is readily available though Jakko.
              Not around here In any case, I think Tamiya used ABS exactly because normal modelling cement won’t work on it, and because it’s stronger than polystyrene, which seems important for a working motorcycle chain. Quite why it has to work, though, I’m not sure. Does the kit have a working engine too?
              • outrunner
                • Apr 2019
                • 2420
                Does the kit have a working engine too? :smiling3:
                No, but you can push it up and down the bench making vroom vroom noises. :smiling3:
                Andy.
                  Andy, I'm in but I'll sit well back , don't want to be bashed by a flying chain !
                  • David Lovell
                    • 2186
                    I'm with Mick on this one good luck. Dave
                      … as long as you don’t accidentally glue the front sprocket to the engine
                      • Andy the Sheep
                        • Apr 2019
                        • 1864
                        • Andrea
                        • North Eastern Italy
                        I'll follow your build 'cause I never saw an individual link motorbike chain.
                        First thing came to my mind is that some graphite powder should help in keeping it flexible.
                        • outrunner
                          • Apr 2019
                          • 2420
                          I built a few links of the chain today.
                          The chain will take a while to build as all the small parts need to be really clean to allow the plates and rollers to fit but at least you can build it in sections then join it all up.
                          Andy.
                            Looks good Andy .
                            • adt70hk
                              • Sep 2019
                              • 10540
                              Looks amazing....but rather you than me!!!!
