Tirpitz with this and that, slow return for me
  • BattleshipBob
    • 6869
    • Bob
    • Cardiff
    #16
    Thanks Steve, afternoon Paul, kind of you!
    Books for research
ID:	1255084 got the superb 5 vol set on Tirpitz, packed with photos by the hundreds plus excellent colour schemes. Wish books like this were done on the Hood etc
ID:	1255085 was going to leave the numerous seams on the bum but what the hell made a start. Going to measure the boot topping and then remove the nasty moulded lines. Next is sand with finer grades etc
ID:	1255086 Click image for larger version
    • Bri62
      • Jan 2023
      • 1973
      • Brian
      • Widnes Cheshire
      #17
      Nice start will be following
      • BattleshipBob
        • 6869
        • Bob
        • Cardiff
        #18
        Right, finally after a lot of playing with pe, using resin and a UV light, pva and then various tyres and makes of ca, applied with metal bar, cocktail sticks and loopers. My confidence is a lot better but way to go!
        So not trying to teach granny to suck eggs, Tirpitz and Bismarck had float plane hangers either side of the funnel. So today started on the port side hanger plus pe
          • 16162
          Just shows how big these battleships were - hangers on a ship! Looks neat work. Often with PE I tack it in place with PVA, plenty of time to get the PE into position and if it goes wrong easy to remove and clean up. I then wick thin CA around the edge.
          • BattleshipBob
            • 6869
            • Bob
            • Cardiff
            #20
            Hi Jim, sound advice
            One method ill be using may also use resin set by a uv torch
            bit more on the hanger, other side should be better
              • 16162
              Looking at that you can see how PE can really create detail not possible with injection moulded plastic. Looks great.
              • BattleshipBob
                • 6869
                • Bob
                • Cardiff
                #22
                Thanks again Jim
                Pleased so far but a mistake or two!! Next is the starboard hanger and the larger one as well
                • scottie3158
                  • 14565
                  • Holbeach
                  #23
                  Bob,
                  My apologies mate, I thought I had commented yesterday. That is seriously excellent bling work mate.
                  • BattleshipBob
                    • 6869
                    • Bob
                    • Cardiff
                    #24
                    Hi Paul
                    Very kind and much appreciated
                    Bob
                    • BattleshipBob
                      • 6869
                      • Bob
                      • Cardiff
                      #25
                      Now playing with the main plane hanger, cut of all the various boat cradles and supports, also moulded on hanger door. Started to fit the pe cradles.
                      Not yet added the front ones, bit of experimenting. The first two have used pva to hold the middle connection, then used a looper to wick pe. The back set have used slow ca on all the connections before fitting.
                      hanger door has been attached with pva, next the looper.
                        • 16162
                        Definitely getting to grips with the pe.
                        • BattleshipBob
                          • 6869
                          • Bob
                          • Cardiff
                          #27
                          Roof boat cradles done phew. Used the excellent dspiae clamp to hold the body, then used tweezers and a looper. Best method i found as long as you counted to 20!!
                          • BattleshipBob
                            • 6869
                            • Bob
                            • Cardiff
                            #28
                            More progress
ID:	1257305 not perfect but pleased that the practice is helping
                            • scottie3158
                              • 14565
                              • Holbeach
                              #29
                              Very neat work Bob.
                              • Richard48
                                • 2173
                                • Richard
                                • Clacton on Sea
                                #30
                                Great P.E work Bob.More patience then me pal.
