Andrew's 1/72 Airfix F-51D Mustang (South Korean Air Force)
OK chaps, so a short update.
The main paint job is now finished. I sprayed on the yellow strip and hand paint the patch below the canopy where I imagine old US markings were quickly covered over (a bit heavy in one case ????).
I think next time I do a metal finish, I will do the coloured parts first and mask them....much easier than having to mask off most of the plane, plus with the metallic finish being smoother it can lead to runs if you're not too careful.
The main thing I did though was to take a gamble and mute the shine of the metallic coat a bit. No matter how you look at the real thing it was not shiny as we so often see depicted. There is a definite light matt patina to it. Whilst no doubt some of the this will be dust and muck, I wonder if some of it down to the aluminium reacting with the air overtime to create an aluminium oxide coat....but whatever the reason it's not nice and new looking, as you can see.
I therefore took a light grey that was a close match in tone to the aluminium (Vallejo Model Air Sky Grey 71.407), mixed it to a thinner consistency than normal - about 1:1 paint/thinner rather than my usual-ish 2:1 - and then gave it a couple of light mist coats from about 6-8 inches. It doesn't show well in the pics but it did have an effect. However, never having done it before I wanted to be careful and so, should I do it again, I will be a bit more aggressive.
FYI, the prop is just dry fitted.
ACW as usual.
A reminder of the real thing
My homage so far......
Great attention to detail Andrew. Paint is looking great and I like the hand pained touch below the cockpit.
Very nice updates and your bird is looking great.
Nice effect on the aluminium Andrew
Thanks as always for the support gents and glad you like the finish. There has been more progress and it's nearing the finish line as we speak.
Steve - glad you like it. Unfortunately the one on the port (camera) side was a bit heavy but the other side has turned out nicely.
Thanks again guys
ATB
Ok chaps, so we're nearing the finish line.....the decals are on and have gone down pretty well but then they are Cartograph, so what else would you expect.
NOTE......A word of warning about markings to anyone wanting to a ROK F-51 or indeed any ROK aircraft. Like the US, ROK planes only have markings on one wing on top and underside***. However, they are on the opposite side to the US practice. Now this is the important bit, both Airfix and Eduard get this wrong, as you will see below.
As you will also see, some of the decals are really rather small, one of the downsides of the doing 1/72!!
That said, I only lost one of them!!
FYI The model has also had the post decal gloss clear coat, so it obviously looks a bit shiny.
ACW as usual.
ATB
***Obviously the RAF approach is the correct one but I'll let that one go!
Proof about the destructions being wrong on the markings front
Courtesy of the article on the South Korean Air Force 1950-53 on the 'Mike's Research' blog.
mikesresearch.com/2022/11/27/south-korean-air-force-1950-53/
The Airfix destructions with my correction (Eduard gets it wrong too):
The photo evidence:
Damn these are small.....
The decals in situ.....
Mustang is looking superb Andrew, and your research for accuracy is admirable. That blog was a very interesting read.
Looking excellent andrew , lovely natural metal finish . Top sleuthing too , just goes to show it pays to do a little digging and research . Nice to see a Mustang in other markings too , cheers tony
Looking lovely Andrew. When that masking comes off and propellor added it will look really well.
Thanks as always for the support chaps, I'm genuinely humbled and glad you found the research useful.
ATB
OK chaps, so we're nearly there.....
The exhaust stains are on, one side went better than the other. I also did a full matt varnish coat, rather than my usual satin/semi-satin, to kill any shiny-ness and to try to represent the matt patina. Not entirely successful as I should have done more of the grey misting coat over the top but it's killed the real shine.
The rockets are drying as we speak, so tomorrow we finished the assembly.
ACW as usual.
OK chaps, so this has crossed the finish line but unfortunately, upon removing the canopy mask, I discovered a band of something greyish across the front of the canopy and a smaller patch in the rear.
No idea what it is....not sure it's a paint because if it had been a leak through a gap, I would expect a lot more within the canopy - plus it's very localised and concentrated - and I would expect to see black from the primer coat too but there isn't. The only alternative is that somehow the new canopy glue I tried reacted in someway but I was put onto it by a good friend and so I know I can trust his recommendation - but I've never had this issue before with any canopies ever.
I've still not made up my mind on how address but I'll work out something.....but I'm not going to try removing the canopy at this stage - that is more trouble than it's worth.
Regardless though I am very pleased with how it's turned out....so much so, I've just ordered another one, to see if I can do a better job!
The matt coat worked a treat in killing an shiny-ness.
A couple of taster shots are below before I do the usual full set.
ACW as usual.
ATB
The potentially offending glue.....
The taster shots....
Any chance of a close up of the canopy issue Andrew. Real sorry to hear about it. I have followed this build from day one and know the work that went into it. It is still a lovely result so well done for that, The only glue I ever use on clear perspex is the Micro Krystal Klear. Amazing stuff.
Well, Andrew, despite the canopy issues that is a cracking model. Very nice indeed.
I have heard that fumes from CA can fog clear parts. Not come across this glue though so can't help, sorry.
Still looks good
Trick with using ca is to apply it then leave for a minute or so to let the fumes vanish then stick parts together....i always use thick ca too
