Scotties Skoda RSO Rich models 1/35.
I have been adding a bit of detail to the front fender. using kit parts, PE and scratched items. I have masked up the engine ready as well. I have added the handrail from copper wire and tweaked up the air filter. I like to replace thin plastic items eg. handrails with wire where possible as they are stronger.
Now for the otherside.
cheers
Scottie
I'd be lost w/o hair dryer motor winding wire (the wife's hair spray clogs the vents causing motor failure, so lifetime supply), bread & rolls twist tie closure wire, and solid 18ga wire from the RR. The copper wire flattens easily for strapping.
Paul,
As an engineer I have a good selection of wire and cables so I'm the same as you a lifetime supply.
Loving the detail Paul I'm always amazed at people who go that extra mile and scratch build stuff :)
The cab is all shaded ready for paint. I meant to take a picture before hand showing the added details. I have detailed the doors with added scratched door handles and window winders. The drivers door as I intend to leave it open I have also added the door catch but again I forgot to take any pictures.
Work now moves to the load bed. Moulded detail was carefully removed and replaced with etch. Each of the nuts were added individually.
There are some nasty ejector marks that need filling.
cheers
Scottie
