Scotties Skoda RSO Rich models 1/35.
I have been adding a bit of detail to the front fender. using kit parts, PE and scratched items. I have masked up the engine ready as well. I have added the handrail from copper wire and tweaked up the air filter. I like to replace thin plastic items eg. handrails with wire where possible as they are stronger.
Now for the otherside.
cheers
Scottie
I'd be lost w/o hair dryer motor winding wire (the wife's hair spray clogs the vents causing motor failure, so lifetime supply), bread & rolls twist tie closure wire, and solid 18ga wire from the RR. The copper wire flattens easily for strapping.
Lovely detail on this Scottie.
Nick
Paul,
As an engineer I have a good selection of wire and cables so I'm the same as you a lifetime supply.
Loving the detail Paul I'm always amazed at people who go that extra mile and scratch build stuff :)
The cab is all shaded ready for paint. I meant to take a picture before hand showing the added details. I have detailed the doors with added scratched door handles and window winders. The drivers door as I intend to leave it open I have also added the door catch but again I forgot to take any pictures.
Work now moves to the load bed. Moulded detail was carefully removed and replaced with etch. Each of the nuts were added individually.
There are some nasty ejector marks that need filling.
cheers
Scottie
Wonderful detailing. As always going the extra mile.
Just a small update. I re detailed the locker doors on one side.
The other side I wanted the locker doors open. The intention is to show an abandoned vehicle. Moulded detail was carefully removed from the drop side and etch replacements added. As well as the etch punced rivets were added and tie downs made from wire.
cheers
Scottie
Top marks Paul.
I have had a go at the tarp the kit offering was actually not bad at all, but I wanted to show it with the canvas damaged and loose at the back. Using the kit part I chopped some of the rear part away I added one metal hoop then PVA soaked tissue. I use lens cleaning cloths as they are fluff free and quite strong. When this was dry I trimmed it to size. I added punched pewter disc and when they had dried completely drilled them to form the eyelets. There was no way I could have married up the eyelets already fitted to the truck so these were removed and new eyelets add to the eyelets in the canvas. When these had dried a rope was ran through. It's far from perfect but should look ok when painted up. There was some blinds on the sides as well these were also added from tissue and masking tape.
cheers
Scottie
