Colin M's 1/48 Airfix Spitfire PR.XIX
Looks interesting Colin. PRU blue Spitfires always look great. That brown and green scheme looks rather out of place on the late mark.
Nice choice of kit - I have the 1/72 kit in the stash. I do actually like the boxart, it makes a nice change from the two tone PRU scheme.
That is a bit odd, I'll have to check the instructions to see if it was a specific thearter of operation. I think the Spitfire's last RAF operational flight was over Malaya, that might have something to do with it ?
I had to look twice at this one Colin when I saw the EE Lightning alongside the Spitfire on the box art. A very interesting scenario.
There’s a story there. I think there was a chance that modern day RAF jet aircraft might encounter Mustangs in Malaya. Therefore Lightnings practiced against Spitfires.
Things have moved on a touch. The interior is ready to be installed.
Bit by bit, the internals were fitted. All behaved and slotted in nicely.
Although the cameras will be lost from sight once the fuselage is closed up.
Nice work Colin. A shame about the cameras being hidden, nice of Airfix to consider the option of someone opening the hatches.
The main components are ready to be slapped together. On a test fit, the wing roots don’t look to bad.
The two holes are for the camera, however. I’m pretty sure the instructions are telling me to fit the glass inside. They don’t fit. Luckily, try from the outside, underneath and they are a perfect fit !
Here’s a bit of detail I nearly missed. No door, due to the pressurised cockpit.
The actual painting of the canopy is presenting a bit of a challenge, it looks possible that the front and rear of the middle section of canopy is frameless. I’m still trying to work this one out. Any other PR builders noticed this ?
Anyway, look, primer. And then some ghost seams to deal with. Where do they come from ?
That's coming on nicely Colin. Didn't realise that theses didn't have a door due to the pressurised cockpit but understand why that would be the case.
ATB
